Fuel Trim - Ford Truck Enthusiasts Forums
Fuel Trim
Old 11-21-2013, 01:42 PM
BassFantasizer's Avatar
BassFantasizer BassFantasizer is offline
Dirty Old Man in training
BassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputation
Fuel Trim
I've posted a couple of times about a lean running 5.4. I've got a bunch more information so I'm starting a new thread keying on the problem.
When I start the truck, the Short Trim on both banks behaves reasonably. Mild variation from about -2% to +2%. The Long Trim immediately goes to +25%. Revving the engine to about 1,700RPM reduces the LT to about 12%, but it immediately shoots back up to 25%.
After a few minutes, both banks throw lean codes and the Check Engine light comes on.
This started more than a year ago when the O2 sensor on the right bank failed. The sensor was replaced and all was normal for a couple of months. Then the lean codes started showing up.
I've replaced the fuel pump, filter, and fuel pressure regulator, yet the problem persists.
Any 5.4 guys out there with an idea, I'm all ears. I'm out of ideas.
Thanks,
~Bass
Old 11-21-2013, 03:38 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Ignore anything before the PCM switches to its closed loop operation for a fully warmed up engine.
You have two sets of each trim, one for each bank. You have to monitor both banks and both trims for both banks to get any insight into the mixtures.
Did you ever check the infamous PCV hose and it's various elbows? It accounts for the huge majority of this set of symptoms.
Old 11-21-2013, 03:40 PM
Yeah. The PCV hose was actually swapped before the O2 sensor. The engine's been tested with the infamous "brake cleaner spray test" and there's no sign of a vacuum leak.
Old 11-21-2013, 08:24 PM
And how was that test executed?
Old 11-21-2013, 08:53 PM
Quote:
I don't know. A mechanic friend tested for vacuum leaks and determined that there weren't any.
Got a suggestion?
Old 11-22-2013, 07:39 AM
Well, there is a way of doing that test that doesn't work (spray and listen) and one that does (spray and watch a scan tool's live data of the O2 voltage or the STFTs).
Depends on which one he did.
Old 11-22-2013, 08:31 AM
My guess is that he did the first.
If the weather allows, I'll hook up my tools at the house and rerun the tests this weekend.
Thanks for the suggestion!
Old 12-05-2013, 09:08 PM
RBlac's Avatar
RBlac RBlac is offline
RBlac is starting off with a positive reputation.
Bass, what did you use for spray? Did you find anything? One of my long term trims seems off in comparison to the other.
Old 12-06-2013, 08:07 AM
Hi RBlac,
I've been on the road (with a different vehicle!) and haven't had a chance to test it yet. If the weather holds, I've already informed the boss (wife) that Sunday is "vehicle maintenance" day. I'll let you know what I find.
Old 12-06-2013, 08:19 AM
Several things work well. Brake cleaner, carb cleaner, ether, unlit propane torch.
Good ventilation is important!
Old 12-06-2013, 05:22 PM
RBlac's Avatar
thanks guys. I was thinking of something like that.
Old 12-08-2013, 08:35 PM
Well this went an entirely different direction than I had expected.
I replaced the fuel pressure regulator and all of the lean issues seem to have resolved. I've put about 2 hours on the truck since then, with absolutely no indication of a problem.
Two different Ford mechanics told me that the pressure regulator had tested OKand in good-natured fashion laughed at me when I told them that I was going to change it. "That's a waste of money. The regulator tested out fine". (3 fuel pumps and 3 filters later, I replaced the $30 part.....)
Apparently, they're not just pass/fail as long trim now varies from -3 to +3, where it was locked in at +25 before.
~Bass
Old 12-08-2013, 10:16 PM
RBlac's Avatar
Good to hear. Thanks for sharing back the results.
5.4 triton codes P0172 and P0174 Achie 1999 to 2016 Super Duty 10 10-12-2015 03:57 PM
5.4L Lean code head-scratcher sundvl76 Modular V8 (4.6L, 5.4L) 16 02-08-2015 09:58 PM
04 Ford Explorer 4.0 Bank 1 & 2 Lean jbizub5192 Explorer, Sport Trac, Mountaineer & Aviator 4 01-16-2015 11:17 AM
CONFLICTING LONG TERM FUEL TRIM VALUES Kevin Parsons 1997 - 2003 F150 21 10-16-2014 02:40 PM
P0174 code, what does lean and rich actually mean? BrassMonkey 1997 - 2003 F150 5 11-21-2013 12:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
