Chuck's Trucks 4.11 conversion?
After a 120 mile trip at the weekend that left my head pounding and my fingers tingling, I realise I need taller gearing.
I know there's the Dana swap, but I'm not going to easily find one here in the UK. So that leaves Chuck's conversion that changes the rear axle ratio to 4.11.
I would like to know if anyone on here has done one, what came in the kit and how the conversion went?
Cheers.
Cheers.
I have his sets in both front and rear axles, he installed them while doing the overall rebuilds of each axle and transfer case. But I haven't gotten the truck operational yet to give an opinion on their performance. I know there are others here that have bought and installed the kits on their own. I'd also get Chuck's description, he's honest as they come. Stu
Cheers.
Cheers.
The stock ratio found in the Timken model 51524 differential used in F-2 and F-3 models is 4.86/1. There was a 4.11/1 ratio listed in the service manual, but not listed in sales literature or in the Chassis Catalog parts books. This ratio was also listed as optional on earlier <47 one ton trucks which used the same axle. Chuck Mantiglia has figured out a way to adapt the 4.11/1 ring and pinion sets that are today reproduced for use with Franklin quick change differentials used by circle track racers. The purpose being to reduce engine RPMs and to allow higher comfortable road speeds. Stu
SeattleF3, I've just ordered it. It's $795 for the kit.
By the way, I would still like to hear from someone who has installed one of these. Apparently the pinion gear assembly can be difficult to get out. There is a tool shown in the workshop manual to pull it out and push it back in. Chuck says he suspends the whole axle by the yoke and heats the casing and hopefully it drops out.
bob
bob
