can i remove the fan clutch for elec. fan
Hello guys i have a f250 2003 6.0l with 240,000 on her and i was thinking about removing the fan clutch? as for mine is dead and ford is telling me $500 for a new one w/plow pak.
can i do this and what is the pro and cons of this ? i do use the truck for plowing 24 lots and towing my g/n trailer 18,000lb and my Daily driver
thanks guys
i know this would make it easier to do some work on it and i could adj. the temp for when it comes on to if need be
thanks guys
Unlike most older-style fans which ran via a clutch which was effected by ambient under-hood temps (remember when vehicles regulary overheated in stop-n-go traffic with the a/c on) - the 6L's stock fan is electronically controlled (using a 'pulse-width-modulated' signal - not really going to work with anything else) by the PCM (computer), the desired speed of the fan is determined by a number of factors which include:
* a/c (or defroster on)
* coolant temp
* trans temp
* oil temp
amongst other things..
So, 'can' be done doesn't mean it would be good for your truck, since the PCM will protect you engine fluid temps FAR better than a simple electric fan.
Plus the stock fan can push/pull a LOT of air when required based on fluid temps getting close to the danger point.. The stock fan can sound like a JET engine when it's required to work hard.
I'm sure the stock fan can be bought from our site sponsor (automation - white bear lake, formerly tousley ford) and shipped VERY economically, and if you can install it yourself you can save lots of $$$.. (just google it, and call with perhaps you VIN # handy in case they ask.. tell them you are FTE for the discount, there is also a thread how to get over-night shipping for <$10 IF you can order on-line)..
Here is the link...
https://www.ford-trucks.com/forums/1...-shipping.html
Welcome to FTE
* coolant temp
* trans temp
* oil temp
Here is the link...
Welcome to FTE
Originally Posted by jetact;13921775[COLOR=red
]Can I buy a fan with a lower set temp[/COLOR] to come on at. I think the temp is to high for when I am pushing it. Yes the fan is great and moves allot of air and it cools quickly but I think if it came on 10 degrees cooler if would be better.
Josh
Here is a custom shroud and Lincoln MarkVIII electric fan for a 5.4 Superduty I made.
It's works really well for the 5.4 and V10 but no way jnwouldnuse it on a 6.0 unless I never hauled or towed anything. It moves 4500 cfm of air on high speed, but even then it wouldn't be enough on grades etc.
Being a puller I doubt there is space between the radiator and engine fan to install this. It would make a killer auxiliary fan if there were space though.
Thanks for the reply, I was just figuring like on big trucks you could buy a sensor or something that would make the fan come on sooner. From what I am reading it looks like the only thing you can do is buy the snow plow fan and it probably runs the same but adds more at lower temps.
Josh
BigMattXXL
1997-2006 Expedition & Navigator
09-03-2003 07:10 AM
