I think I broke an axel
You will still have to set up your gears with a new carrier. Plus buy a bearing kit...that's probably another $100. It's a shame your on the west coast I could out you in touch with complete 9" for $200 or less. I would seem to think you could find another 9" out there and rob the center section with gears already set up.
Setting up gears for the first time is best done with a mentor.
You broke the carrier in the exact same spot I did years ago on a 77 F150. Stock 350 engine and tiny donut tires with an open carrier...I tried to do a hole shot and "BAM". I am scared to beat up on a stock 9" now.
There are many 9" axles in junkyards. All I did was buy another complete 9" axle for $100 and just swapped it in. Way cheaper and quicker than starting from scratch.
My axel ended up being fine. Looks like this is what I might need. Does this look about right guys? I'm not trying to spend a lot of cash.
Summit Racing® Ford 9 in. Trac-Loc Differentials SUM-CTF9TRACL31 - Free Shipping on Orders Over $99 at Summit Racing
3/8" means you have the small bearing.
This will not have any effect on what case to get. All that matters is that the axle spline count and the carrier spline count is the same.
maybe you guys can take a look at this case for me. Is this a standard case? I already bought the carrier and bearing set I just want to make sure everything goes together. Thanks.
http://broncograveyard.com/bronco/i-...-062-bore.html
annaleigh
43
05-22-2018 03:27 AM
mybigredford4x4
03-16-2014 05:16 PM
5.4L to Freedom
1999 to 2016 Super Duty
27
11-29-2009 03:33 PM
