I think I broke an axel
Old 11-21-2013, 01:09 AM
biggyfan1's Avatar
biggyfan1
biggyfan1 is offline
well I was messing around in the truck on the street in first gear and I got some wheel hop and then I heard a loud crack! Now the truck doesn't move when I put it in gear. I was able to drive it home by putting it in 4 wheel drive. Once I got it home I put it in first gear and the truck doest move but the drive line spins and makes some very bad noises while it does haha. Think it's an axel or rear end?
Old 11-21-2013, 01:33 AM
79beaterbilt's Avatar
79beaterbilt
79beaterbilt is offline
well since it says u have a f100.... id say........ u killed the spiders.... as if the axle was broken the axle would've slid out still bolted to the rim
Old 11-21-2013, 02:39 AM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
On a Ford 9-inch? I doubt it. The axles are held in with a plate which in turn keeps the pressed-on bearings in place. Generally, the only way it could slide out as described is if the axle breaks on the outboard side of the bearing or a sheared bearing which allows the axle to slip off.
...spiders, sheared pinion teeth, or ring gear teeth. Time to open 'er up and take a peek.
Old 11-21-2013, 08:34 AM
rogue40's Avatar
rogue40
rogue40 is offline
And don't forget the pictures!
Old 11-21-2013, 09:28 AM
biggyfan1's Avatar
biggyfan1
I will be sure to post some pics. Maybe even a video of the blender with marbles sounds. Do these f100 's have posi? What would be the best way to tell what axel is broken?
Old 11-21-2013, 09:35 AM
rogue40's Avatar
rogue40
rogue40 is offline
It is probably not an axle shaft but you will know when you take it apart.
I'm betting on the Traction-Loc clutches letting go.
Old 11-21-2013, 09:45 AM
parkerparkerm's Avatar
parkerparkerm
parkerparkerm is offline
Posi is a gm term but I know for a fact my 76 f150 has a 9" that locks up in just about one tire rotation, so you could say it has a Posi. I don't know if the f100s do though.
Old 11-21-2013, 10:12 AM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,286 Likes on 2,442 Posts
I believe for a 9" you have to pull the axles out first, meaning remove all the rear brake stuff and plate that HIO is talking about.
Then the center chunk (carrier housing) from the front, it does not have a rear dif cover like a Dana 60.
You will see whats broke once you get it out, pic are mandatory at this point.
Old 11-21-2013, 11:29 AM
HIO Silver's Avatar
HIO Silver
The axles can be withdrawn without removing the brakes. Four retaining bolts (nut side) are accessed through a hole on the axle flange. 'Only has to be withdrawn about 10 inches or so to clear the center section, indicated by a telltale "clink".
A center section can be swapped in as little as one hour.
Old 11-21-2013, 11:33 AM
77&79F250's Avatar
77&79F250
You 1/2 ton folks have is so easy, I was kinda guessing. I have pulled a 9" axles before, a friend needed all the rear brake stuff and the CENTER CHUNK 4/11 posi.
Then I pulled the front R&P out for him, cause his was stripped.
Old 11-21-2013, 03:32 PM
biggyfan1's Avatar
biggyfan1
Here are the pictures. Looks like the clutches and bearing cap shattered. What do you guys think? What should I buy to fix this?
Old 11-21-2013, 04:53 PM
biggyfan1's Avatar
biggyfan1
I might need to get everything that can drop in to my center section. Clutches are gone, bearing cap, etc.
Old 11-21-2013, 06:04 PM
biggyfan1's Avatar
biggyfan1
This might help to determine what parts I need.
Old 11-21-2013, 07:06 PM
PA74F250's Avatar
PA74F250
PA74F250 is offline
I think I would just buy another axle and swap center section. It would be a lot quicker,
Old 11-21-2013, 07:07 PM
biggyfan1's Avatar
biggyfan1
My axel ended up being fine. Looks like this is what I might need. Does this look about right guys? I'm not trying to spend a lot of cash.
Summit Racing® Ford 9 in. Trac-Loc Differentials SUM-CTF9TRACL31 - Free Shipping on Orders Over $99 at Summit Racing
Quick Reply: I think I broke an axel
