Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
  #1 (permalink)
Old 11-20-2013, 08:25 PM
g-man-75 g-man-75 is offline
g-man-75 is starting off with a positive reputation.
2wd lift
Hi all I am wanting to lift the front of my '74 F350 Super Camper Special 2wd in order to fit 35" tires on it all the way around. I'm sure no one makes a kit for it, but I can custom order springs. Any idea how much lift would be required and with the twin I beam would there be enough room for proper adjustment on the camber?
Before everyone attacks me I have my reasons... I'm planing to convert it to 4wd but in reality its another year or two down the road. I have a '73 4wd parts donor, then I realized my front gas tank is in the way of the transfer case among other things and with further research I want to use axles from a late model Dodge, keeping the front coil set up and gaining 4 wheel disc brakes. I ultimately want to run 35's so why not mount them now, as it will keep my RPM's down on the freeway and I live on a bumpy, pothole, wash board road and the larger diameter really helps, besides that it just looks cool! Thanks in advance for your input!
  #2 (permalink)
Old 11-21-2013, 07:37 AM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
Here's a thread about a really nice lifted 2wd:
http://www.ford-trucks.com/forums/98...-2wd-f250.html
__________________
Old truck: 74 F250 Converted 4WD sold
Some other 4 wheeled vehicles also reside in the driveway
  #3 (permalink)
Old 11-21-2013, 10:37 AM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Workaholic
77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of
Fabtech makes a kit $$$ Its a pre runner set up you are looking for.
As far a converting your 2wd to 4wd you are in for a long hard road. Best bet would to swap you body on to the existing 73 4x4 parts doner, if you have the frame w/running gear.
Here is some 4x4 conversion info copy and past for you.
There is nothing nuts and bolts about a 4wd conversion, there is not a thing that is bolt on or swappable. The engine cross members are entirely different, and this means that if an un molested truck is what you are after, it will be impossible to create one with a 2wd platform. The 2wd will have to be lifted quite a way to clear the front diff.
2wd trucks are coil sprung and most F250 4wd's are leaf sprung. None of the suspension items are even close to the same, so you will be fabricating or modifying some original 4wd stuff to work. Steering systems are entirely different as well, so you will be upgrading that too.
My last conversion with leafs ran me several thousand dollars, and that was with the work that I performed for free. The difference in sale values between a 4wd and 2wd are minimal, and the 4wd conversion is hardly justifiable. How far away are you looking? I pick up F250 4x4's for reasonable money. Consider the cost of shipping, and then consider buying a west coast truck with no rust, and I can guarantee that you will be time and money ahead.
Well the frames are similar, with a few exceptions. The frame horns are slightly different, and the frame widths aft of the cab ar different from 73 to 77 trucks. The frame rise is also slightly different, but this is not a show stopper and does not make much difference one the fabrication begins.
Not that the important question is whether or not you will be using a coils springs or a leaf spring. It is possible to install a 78/9 radius arm and suspension. Not a big deal really, and with a standard cab this is reasonable. Not quite as easy with a super cab and or crew cab.
The 2wd frames are not cut for the shackle pivot, and they do not have the provisions for a spring hanger, but again, this is not a deal breaker. Installing a pivot is just a tedious process. Accuracy is key, but I am not telling you anything that you do not already know.
Ok, so next is the transfer case. You have two choices, Install a married case, and this requires the proper transmission. Might find some difficulty making or modifying an output shaft to accommodate the early C6 and a married transfer case. So then the next option is to find a divorced transfer case, and install this. You will have to make up a cross member, but then you will have to get creative with the shifter linkage. See the 4wd trans will have an adapter or tailshaft with a pivot for a typical 205 shifter.
Fabrication is the only limiting factor here.
Next and final factor will be the speedo. See your speedo works from the trans, so that being the case, you will have to get a speed reference form the t-case. If you do not, the speedo will read twice as fast when you put the case in low range.
As mentioned the steering box will have to be relocated, and the truck will require some lift. That engine crossmember has limited clearance so you will be looking at some lift to even clear it. The other option would be to remove it and replace it with a tubular unit.
This is a heck of a project. Not unreasonable, but a project none the less.
2500 bucks for a 2wd might get expensive. I paid 1300 bucks for a 4wd 75 last year, and it was already 4wd with 38" tires, and a strong 460, A/c, and plenty of goodies. I have made these conversions, and can tell you that it is a chore.
__________________
77&79 F250 Rich & Penny
77 351M auto, factory a/c add a leaf 33x12.50's
78 (79 headlights) 460 4 spd, factory a/c and 35's
79 351M 4spd 6" Skyjacker Edelbrock-Holley-Hedman 35's
99 Ranger 4x4, 98 Expedition 4x4, 73 Bronco Hillbilly-Bug
71 Bronco 302 35" Boggers 5.58 gears spool/locker
  #4 (permalink)
Old 11-21-2013, 01:46 PM
Justin.Hoeben's Avatar
Justin.Hoeben Justin.Hoeben is offline
Justin.Hoeben is starting off with a positive reputation.
I fitted 33inch tyres to my 79 F100 2wd and it would rub now and then. I wanted to do a suspension lift but after doing some calculations and research doing a suspension lift will cost me more than what my truck cost me. So know my only options would prob be a body lift.
__________________
1979 Ford F100 2WD 300ci Inline 6, RHD
Slow is smooth and smooth is fast...
  #5 (permalink)
Old 11-21-2013, 04:29 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
Quote:
They do????
Got a link to it?
My thought is you meant Autofab, but I'd love to see what the deal is if Fabtech made something
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #6 (permalink)
Old 11-21-2013, 05:56 PM
Thanks for the great info guys, just talked to AutoFab they have exactly what I need. They're only 120 miles from me so I'll stop by and check out their shop. Guess us desert rats are the only ones who lift 2wd's. Might leave well enough alone and keep it 2wd and get rear ARB locker, that way I can spend my money on a gear vendor instead
  #7 (permalink)
Old 11-21-2013, 06:08 PM
Autofab does good stuff. You'll be please with your purchase. John, Darrin, Tiff & the gang are good, KNOWLEDGEABLE people for sure!
__________________
1970 Ford F250
  #8 (permalink)
Old 11-21-2013, 07:37 PM
teds74ford's Avatar
And now for grins, here's another option:
http://www.ford-trucks.com/forums/97...y-of-pics.html
Since I haven't tried it, I won't recommend it, but it does fascinate me. Maybe one day...
__________________
  #9 (permalink)
Old 11-21-2013, 09:31 PM
77&79F250's Avatar
Workaholic
Yes Chase you were right and my memory was wrong, thanks for picking up the fumble.
__________________
  #10 (permalink)
Old 11-22-2013, 01:49 PM
No worries. You had my hopes up for a second that someone else was actually paying attention to these old trucks, and the 2wd ones to boot! Oh well. As I said before Autofab stuff is good stuff so I'm fine with it.
Little side note tidbit here:
Fabtech started as a local fab shop in Fullerton, CA. I remember going there when the 2wd lift kits were just starting to take off along with the "prerunner scene". That shop changed names when Fabtech name & lift kit line was sold & became a rancho type deal. In the good old days Fabtech, Camburg & pretty much all others would would use autofab bent beams in their more entry level type lift kits that didn't go to a custom fabricated i-beam.
__________________
1970 Ford F250
  #11 (permalink)
Old 11-23-2013, 12:04 AM
77&79F250's Avatar
Workaholic
I have had only one 2wd dent side Ford truck, a 73 and all the others have been 4wd. I really like the prerunner look, the bumpers and roof rack is definitely different and cool IMO.
The 79 4 door prerunner dent is even cooler.....
You never really see a prerunner style truck out here in the mid west, we have more mud than sand, so it makes sense.
__________________
  #12 (permalink)
Old 12-03-2013, 07:10 PM
Guy I know on another forum owns that yellow one you show the pic of. It was for sale on race-dezert.com a while back & I had to keep my checkbook at bay as I was tempted.
Side note - I found (well cheet-o pointed me to it) the closest thing I've ever seen to what I want to do on facebook the other day. So cool even that I'll take the time to load the pic in my photosuckit account & post here!!!
Crew cab on a supercab, short bed frame (notice the bedsides tucked into the cab!) with a d50 TTB up front & full cage. Only difference I'd be looking at would be possibly doing it on a std. cab, long bed frame to get the wheel base even shorter.
__________________
1970 Ford F250
  #13 (permalink)
Old 12-04-2013, 09:19 PM
teds74ford's Avatar
Now that's pretty cool!
__________________
  #14 (permalink)
Old 03-31-2014, 07:25 PM
Off to Autofab tomorrow for a 5" lift! Took a long time to get to this point but since my last post I popped in a Lunati Voodoo bumpstick and ditched the tired C6 and I rebuilt and installed a np435. Anyone know what a good wheel offset would be for this setup? I plan to run 35x12.50x17, probly a 17x9 rim. Just hard to visualize what I need because I have pizza-cutters on the truck now. I don't like tires sticking out far and don't want clearance issues. Thanks
__________________
'74 F350 scs 390/435.......never ending project
'63 Fairlane 500..............never started project
'12 F450 V10..................daily driver
  #15 (permalink)
Old 04-01-2014, 08:30 AM
teds74ford's Avatar
I run H2s
Click the image to open in full size.
They are 8.5" wide, have 5 5/8s backspacing and don't stick out. The only thing is that I think they would rub the radius arms with 35s. They are kind of close with 265s, and I think 33s would barely rub (or miss) the radius arms at full lock.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
2wd or 4wd lift kit? jason832 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 07-25-2014 01:20 PM
2007 F-250 PSD Suspension Lift CountryMonkey07 Super Duty & Heavy Duty 9 05-15-2014 03:37 PM
RSK 3.5" OR 4.5" and Component Questions nossliw 1994.5 - 1997 7.3L Power Stroke Diesel 7 05-07-2014 03:18 PM
Drives like a dream now!!! bigsnag Super Duty & Heavy Duty 3 03-31-2013 12:45 PM
2wd excursion level help Gwolff73 Excursion - King of SUVs 8 03-04-2013 07:17 AM
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
