The title says it all. I have a 400 with a 4x4 oil pan (rear sump--double hump) will it fit a 4x2. Also what size is the 4x4 pan --it's from a F 250. I know the 4x2 takes a front sump pan, but it looks like a 4x4 might fit. 4x4 is a 78 F 250, 4x2 is a 79 F 350. Thanks.
It fits. Just swapped my 78 2wd's 400 to a 79 4wd 351m. Didn't change the oil pans an actually fits the 4x4 pan better. I believe my pan was a 7 quart pan...I may be mistaken though on that one.
Thanks guys. It seems like the 4x4 pan is a larger capacity pan also. A plus. Has anyone had a problem with the LONG 4x4 oil pickup (cracking, coming loose etc)? Thanks again
