2003 ranger stalls/shutters on acceleration - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-20-2013, 07:32 PM
jbarn jbarn is offline
jbarn is starting off with a positive reputation.
My 2003 ranger, 4.0l, 5 spd manual with 295K miles has no power on acceleration. Engine shutters/stalls. The following have been replaced in last 20k miles; fuel pump, plugs/wires, mass flow sensor and fuel filter. Last week left for work and could not go faster than 50 mph. Condition has gotten worse (barely goes past 40 mph). Changed filter with no improvement. Checked fuel pressure - constant at 65 psi. Changed coil - no change. Can anybody help? Thanks! P.S. The tank of gas I put in just before problem was from station with tanker dumping while I pumped. That tank is out of truck; filled from different station. Also put can of seafoam in tank. No change.
Old 11-22-2013, 09:07 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
My first thought would be a lack of adequate fuel delivery, and you seem to have addressed that possibility with a new pump and filter. 65psi is good pressure as long as it remains constant, even during hard acceleration.
Keep in mind that fuel injectors also have screens in them that can get clogged up.
If it is a fuel delivery issue, then I have to think that at some point you will be getting some kind of lean codes.
'79 460 wanting to stall? 74 F350 SCS 1968-2013 Full Size Vans 6 12-17-2015 04:09 AM
2004 Ford Explorer fuel/acceleration issues mhofmann86 Explorer, Sport Trac, Mountaineer & Aviator 2 09-22-2015 04:45 AM
1998 Ranger electric fuel pump. SwampFox112 Ranger & B-Series 9 01-18-2015 03:19 PM
04 f250 6.0 rough I idle and shutters at 60 mph dgulledge 6.0L Power Stroke Diesel 48 11-04-2014 10:23 PM
Getting a shutter yasky69 6.0L Power Stroke Diesel 25 07-04-2014 08:13 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
