1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Question 99 f250 sd. V10
Old 11-20-2013, 02:41 PM
Jnowaczyk's Avatar
Jnowaczyk
Jnowaczyk is offline
I've been working on this truck for weeks. Latest codes p0172. P0174 lean on one bank rich on the other fuel trims are good only when I shut it off and turn back on stays good for 30 sec then go out of whack. I have no cat. It was removed before I got it. If I replace the cat would it help on the fuel trims ?
All hoses been replaced along with o2s both upstream. . Iac. Tps cps. PVC valve
And fuel filter and pump also maf replaced.
I sprayed the intake. Can't find a leak
Can anyone think what else could cause the. The problem Cats ? Pcm ? Any of the egr stuff
Fuel pressure is 35- 45
Old 11-20-2013, 06:08 PM
senix's Avatar
senix
senix is offline
Received 1,410 Likes on 1,006 Posts
bump it for you. Hope that someone has some ideas.
Old 11-20-2013, 06:20 PM
redford's Avatar
redford
redford is offline
Received 1,559 Likes on 908 Posts
It sure sounds like you have a vacuum leak.
Old 11-20-2013, 06:28 PM
Jnowaczyk's Avatar
Jnowaczyk
Lean side or rich side.? I can't find a thing. The only thing I can think of would be the Evap cansiter purge valve. Faulty as that has vacume from the intake. Evan thou I have all new hoses could be leaking from the inside.
I don't have a vacuum gage but I guess it's time for one. Or rent one.
Didn't think it would be that. Because of one side rich other lean. I could see it if it was a po171 and po174. Both lean
Old 11-20-2013, 06:31 PM
redford's Avatar
redford
redford is offline
Lean side. The PCM is trying to compensate for too much air by throwing more fuel at the engine, which is causing the other bank to go rich.
Old 11-20-2013, 06:32 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Is the truck missing ? Have you reset KAM ? Do you have live data ?
Old 11-20-2013, 06:49 PM
Jnowaczyk's Avatar
Jnowaczyk
No misfires Reset the kam from my meter Reset the pcm. I do have live data
Old 11-20-2013, 06:51 PM
Jnowaczyk's Avatar
Jnowaczyk
I'm going to go rent auto zones vacume tester tomm. See what I can find. Just at a loss.
Old 11-20-2013, 06:53 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Use propane and a small hose . Watch short term fuel trims while searching for a vac leak .
Old 11-20-2013, 06:56 PM
Jnowaczyk's Avatar
Jnowaczyk
Ok I'll try that I have a tank have to find a valve don't want to cut my grill. Lol. Or could I use a propane torch ? Un lit of course. Could stick a hose on thar for a few bucks.
Old 11-20-2013, 06:59 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
I use an UNLIT torch and a length of hose . Good luck Graph the data pid if you can . Better than trying to watch some bouncing numbers .
Old 11-20-2013, 07:01 PM
Jnowaczyk's Avatar
Jnowaczyk
Well at least I have some stuff to try. Thanks. Send any other things I can try. I'll do the vacuum tester first and check a few sensors that could leak internally if bad then I'll move on to propane .
Old 11-20-2013, 07:04 PM
Jnowaczyk's Avatar
Jnowaczyk
I'll take my ipad and do a video. And send it your way tomm. By email if you can pm me your email. Thanks !!
Old 11-20-2013, 07:07 PM
Jnowaczyk's Avatar
Jnowaczyk
Jwc. What do you want me to graph. Short trim. Long trim ? I think I can fit 4. On the screen
Old 11-20-2013, 07:14 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
While looking for vac leaks , graph short term . If you graph long term, while driving , you can see what the ecm wants at different load cells . Tack on a graph of maf and tps while driving and you can get a lot of useful info . That is , If you know what to look for .
Quick Reply: Question 99 f250 sd. V10
