When to Box????
When to Box????
I am getting going on my 53 project... I am planning on putting the Mustang II front end on it but, When do I box the frame?
Should I put the Mus. II front end in first and then Box or, Box and then put the front end on?
Also, I haven't purchased the front end as of yet. I have been told by one guy to not buy the weld in kit. I haven't seen a bolt in kit and don't know if they are even available. *** Just looking for a little advise ***
Any good MII kit will come with the appropriate boxing plates for the front rail section. If you use those as instructed you'll be fine. The do go in prior to the installation of the crossmember. Weld in kits are better than bolt in, imho, as long as you or someone you know has the necessary skills to install one correctly. If not, the bolt in kit from Chassis Engineering is an excellent alternative.
http://www.heidts.com/Content/Instructions/in-092.pdf
I've been looking around online and found many different options for IFS. I found a couple on E-bay and was wondering what the feeling on them were....?
1953 54 55 56 Ford Truck Mustang II IFS Front End Kit Power Rack Drilled Rotor | eBay
1948 56 Ford F 1 F 100 Front Suspension Disc Brakes IFS Front End Kit F1 F100 V8 | eBay
1953 56 Ford Pickup Truck Mustang II IFS Front End Suspension Kit 1955 1954 F100 | eBay
I did take a look at Speedway Motors and they seemed like a good deal but I didn't see all I needed to buy.
I'd like to stay under $1700 if possible.... Please Help!!
good luck putting in a MII style IFS worth having for under 1700.00! There are a lot of hidden costs that are not part of any kit that will bring the total to closer to 3000. - 3500.00. If you are on a tight budget then there are far better choices than an MII. If you must have an IFS (reason???) then the Jag would give you a better IFS at 1/2 the cost, and the OEM beam axle/leaf spring style suspension can be upgraded to equal almost any IFS for highway driving at 1/3 the cost, and 25% the time and labor, and absolutely no welding necessary.
I'm just talking about just the IFS kit. I know it still have steering linkage and break hoses and other things like that to make it work. But I would like to keep the kit itself under $1700. NowI see eBay has a few choices under that price I am just wondering if they are worth the money or not.
http://www.totalcostinvolved.com/pdf..._Front_End.pdf
