Question 99 f250 sd. V10
I've been working on this truck for weeks. Latest codes p0172. P0174 lean on one bank rich on the other fuel trims are good only when I shut it off and turn back on stays good for 30 sec then go out of whack. I have no cat. It was removed before I got it. If I replace the cat would it help on the fuel trims ?
All hoses been replaced along with o2s both upstream. . Iac. Tps cps. PVC valve
And fuel filter and pump also maf replaced.
I sprayed the intake. Can't find a leak
Can anyone think what else could cause the. The problem Cats ? Pcm ? Any of the egr stuff
Fuel pressure is 35- 45
Lean side or rich side.? I can't find a thing. The only thing I can think of would be the Evap cansiter purge valve. Faulty as that has vacume from the intake. Evan thou I have all new hoses could be leaking from the inside.
I don't have a vacuum gage but I guess it's time for one. Or rent one.
Didn't think it would be that. Because of one side rich other lean. I could see it if it was a po171 and po174. Both lean
Ok I'll try that I have a tank have to find a valve don't want to cut my grill. Lol. Or could I use a propane torch ? Un lit of course. Could stick a hose on thar for a few bucks.
