1995 E250 strange problem - transmission?
#31
I had to make myself a special tool to get that dang cable housing off the brake assembly.
They probably have a proper tool available by now since it's been 24 years.
#32
Latest update: my mechanic turned my van over to a transmission shop that has the right equipment to read the codes...but as of this posting, they haven't been able to get the problem to occur. I told them to keep it until it does! I don't want it back with the problem not corrected.
If I have to, I'll go there everyday and drive it myself until it does occur!
#33
That one will cause problems to be there one minute, then gone the next.
#35
Or any $30.00 OBD-1 code reader will read them.
Or most auto part stores can read them for you also.
I would not take anything back to a mechanic that can not read codes.
#36
"I would not take anything back to a mechanic that can not read codes."
That is your choice, I see no reason to give up on a good mechanic who has one limitation. If the issue of reading the codes comes up again, I can always have the choice to go elsewhere. Otherwise, I'll stick to a good mechanic who can do most of the routine stuff quickly and well.
#38
"most good trany shops use a computer and see data in real time, and save data too. when driving vehicle for Diagnostic purposes"
The problem is, and has been since when the problem started, that the problem doesn't occur for THEM! But I spoke to the mechanic at the transmission shop and they found a couple of instances from another forum that were similar to mine and both of those turned out to be the PSOM. So right now they're in the process of getting one to put in my van. Here's keeping my fingers crossed!
#39
#40
Latest update
Here's the latest on my van:
About a month ago the mechanic sent the PSOM out of state to be checked. Checked out bad, and wherever they sent it replaced a bad diode. Mechanic reinstalled it and called me to pick it up. No deal, it still failed. But THIS time I was actually able to get it to fail while the mechanic was in the van...BIG improvement. At least they knew it really DID have a problem!
Anyway, they took out the PSOM and sent it back. This time the whole circuit board was replaced...at no additional cost to me.
I picked up the van last Thursday (2/6/14) and was actually able to get to the Interstate. So I kept driving. Interstate, 2 lane roads, you name it...I put about 100 miles on it. NO PROBLEMS! Transmission shifted fine, cruise control worked. So for the next few days I took it out whenever I could. Short drives, long drives...NO PROBLEMS!
I still hold my breath whenever it shifts...but I'm slowly getting over that and I'm actually planning some long distance trips in it. So, at this point, looks like it really IS fixed this time!
#41
Way back when they came out with the E4OD (89?) I worked at a dealership rebuilding them.
I was never able to drive an automatic without focusing on the shifts the transmission made judging the timing, smoothness and how it sounded.
I sold my automatic mustang shortly thereafter, and until about 5 years ago have never owned an automatic.
The only automatics I fully trust now are the old C4 and C6 models.
#42
"I sold my automatic mustang shortly thereafter, and until about 5 years ago have never owned an automatic."
Yeah, well...more power to you...but I think it's just a tad late to be talking about a manual shift for a nearly 20 year old van! I've had both and for a vehicle the size of my van I wouldn't even consider a manual transmission.
#43
Doggone,
Your description of what your van was doing is exactly what my '96 F350 is doing right now. Are things still going as they should? I found a place online (located in WA that says they repair PSOM's, I am about to send my instrument cluster to them so they can fix it. If they can repair the board it sounds like I'll be good to go.
#44
#45
