BW1345 NP205 Transfer case Swap question
Old 11-21-2013, 03:53 PM
cadunkle's Avatar
cadunkle
cadunkle is offline
May need to grind/cut a hole in the adapter on tail housing on trans as one of the 205 shift pins will hit without the notch. Shift linkage will typically just require lengthening or shortening to your required length. Pretty trivial. You may have issues with the front drive shaft and your crossmember though. I expect the crossmember will get in the way and you'll need to make your own or modify the factory to clear.
The following users liked this post:
Old 11-21-2013, 04:24 PM
bruno2's Avatar
bruno2
bruno2 is offline
Those 205's are heavy behemoths of transfer cases. I would seriously consider possibly adding a cross member or something to help support it too.
Cast iron case and full of gears. That's a lot of weight hanging off the back end of a tranny.
Old 11-21-2013, 06:48 PM
garthneddy's Avatar
garthneddy
garthneddy is offline
The factory crossmember will require zero modifications for driveshaft clearence. If you have a newer style trans such as the ZF5 you WILL NEED to support the NP205 somehow. I simply used a factory torque mount from the 78 I pulled the t-case out of and it's worked very well.
If you have an NP435 or C6 then just bolt her on.
Old 11-22-2013, 09:02 AM
bullnose1985's Avatar
bullnose1985
bullnose1985 is offline
Originally Posted by ArdWrknTrk
Welcome to the forum, Jon!
Thanks Jim it's good to be here.
Old 11-22-2013, 09:14 AM
bullnose1985
Lightbulb
Cadunkle, I see you have a 86 f250. There are more of theses old bull noses out there then I thought. Thanks for the info! The 205 I was looking at is a divorced version. So I am far from putting one in. Do you know if it is possible to convert a Divorced Transfercase To A Married Transfercase?
Old 11-22-2013, 09:27 AM
bullnose1985
Hi Bruno2, I understand the weight issues, but you can't have heavy duty without heavy. The main purpose for this truck will be to clear acreage and hall rocks. So I figured it would be better to be safe then sorry. I bet I will take a beefy crossmember to keep things solid. Thanks for your help, jon
Old 11-22-2013, 02:42 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,654 Likes on 1,337 Posts
You can save a lot of work by just keeping the transfer case you have. They are strong enough to pull anything you can hook to the truck. You can say "I told you so" if you ever break it, but I doubt you will.
Old 11-22-2013, 02:49 PM
bullnose1985
[QUOTE=Franklin2;13768901]You can save a lot of work by just keeping the transfer case you have. They are strong enough to pull anything you can hook to the truck. You can say "I told you so" if you ever break it, but I doubt you will.[/QUOTE
Hi Dave, I am beginning to think your right. Maybe it's not the case? I am hoping to get some time to look at it this weekend.
Old 11-22-2013, 06:28 PM
bruno2's Avatar
bruno2
bruno2 is offline
I think that divorced/married thing is going to be an issue.
Old 11-22-2013, 07:54 PM
bullnose1985
How is that be bruno2?
Old 11-22-2013, 08:00 PM
Franklin2's Avatar
Franklin2
You will need a 2wd tranny if you are going to use a divorce style transfer case. And also a much shorter rear driveshaft and a much longer front driveshaft and custom transfer case mounts/crossmembers.
Old 11-22-2013, 10:20 PM
lonewolfone's Avatar
lonewolfone
lonewolfone is offline
I swapped a np205 into my 82, I had to modify my trans cross member, make a custom trans mount, get driveshafts lengthened/shortened and used the og 205 shifter bolted up and modified the linkage between it and the t-case to make it work.
  #28
Old 11-23-2013, 06:21 AM
garthneddy's Avatar
garthneddy
I'm curious to know what made it necessary to modify the factory crossmember and trans mount with your NP205 swap. Was it driveline clearances?
I've also finished an NP205 swap and reused the factory spec crossmember and trans mount, both completely unmodified.
  #29
Old 11-23-2013, 10:04 AM
lonewolfone
My f250 originally had the cross member with the extra plate and bushings between the two for the trans mount. The parts truck that donated the idi and axles is the cross member I ended up using because it had a better drop section to clear the np's massive drop. I then made a custom mount for the new cross member because the trans bolt holes sat offset to the 91 cross member, made the mount out of some 1/2 inch plate and thick walled 2 inch square tube.
  #30
Old 11-23-2013, 10:08 AM
lonewolfone
Forgot to add I'm running a np435/ np 205 an idi and Dana 60 king pin front end the truck is an 82 and used a 91 auto trans cross member.
Quick Reply: BW1345 NP205 Transfer case Swap question
