2001 f350 dually now 4x4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-19-2013, 03:57 PM
keyvangarcia239 keyvangarcia239 is offline
keyvangarcia239 is starting off with a positive reputation.
I have a 2001 f350 dually that was originally a 4x2 but now i put a 4x4 front axle. I bought a three inch front leveling kit for dually 4x4. I also want to lift the back so it isn't so low. Any body have any Ideas on what size rear block I should put?
Old 11-19-2013, 04:35 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
I want to say the stock block on a 4x2 F-350 is a 2 inch block, but not sure if that applies to a DRW truck.
Old 11-20-2013, 11:07 AM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
install the front lift and 4x4 axle set it on the ground and then measure to see how you want the rake to be. If its level after the front install go about two inches higher in the rear, so if you have a stock two inch rear block go to a four inch block
Vibration/grinding on front drivers side after partial rebuild Storm Knight 1999 to 2016 Super Duty 3 01-10-2017 09:46 AM
stock front/rear 04 f350 dually suspension on 01 excursion? ufvj217 Excursion - King of SUVs 13 11-14-2016 03:39 PM
WTB Dually wheels Warhippie WTB - Parts & other 1 09-10-2016 12:18 AM
2001 f350 front bumper conversion. fordrocks96 1999 to 2016 Super Duty 7 08-01-2016 12:06 AM
Dually vs single hubs? Vinford 1999 - 2003 7.3L Power Stroke Diesel 4 03-02-2010 10:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
