White Lightnin' Build thread (88 F150 4x4)
#121
on
Picked up head bolts yesterday. Now I have to wait to get money for the other head gasket, oil, oil filter, trans fluid, coolant, and other small things like that. That's fine though I still have to clean up the new engine, pull the heads off mine, pull my old engine, clean up my engine compartment, take the top end off the new engine, install the oil pump, and a few other small things.
Plus I have a little bit of work to do on my brother's ranger and my explorer so all is good.
Trav
Trav
#125
on
Pulled the engine that was in the truck out and found the oil pump driveshaft at the bottom of the pan covered in gunk about half of the oil pan. Also found the rod bearing and part of the cylinder wall. The block is done for so hopefully this one is rebuild able otherwise time to get a crate.
Trav
Trav
#126
on
Well brought in the block from my buddy to the machine shop and they told me it needs bored at least .030 over. I told him let me know if it goes over .030 over as I don't want it over .030 over.
Verdict of everything I need:
rebuild kit
cam and lifters (staying stock as that's all that is in the budget right now)
rebuild heads (again staying E7TEs)
new water pump
motor mounts
transmission mount
polish the crank (he said it looks great otherwise)
So over the months I will be slowly rebuilding the engine.
Trav
rebuild kit
new water pump
motor mounts
transmission mount
Trav
#129
on
Well a few pictures of some things right now.
The heads after cleaning them up (still stock E7TEs that I am going to rebuild) (I know have all the valve springs, valves, and rocker arms off.)
White Lightnin' without an engine (I haven't gotten any pics yet of the engine since having it baked and bored):
#132
on
A member here (unfortunately for some reason I can't remember his name) told me about summit and since I have been going their to check prices. This is our first order through them though.
Pistons are suppose to be here today rings tomorrow or Friday. How in the world that happened I have no idea but not complaining at all.
Trav
Trav
