Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-19-2013, 01:54 PM
7.3fire's Avatar
7.3fire 7.3fire is online now
7.3fire is starting off with a positive reputation.
97 PSD Build Up!!! On A TIGHT Budget!
Well guys, i went out and bought my dream truck yesterday, my first truck and my first diesel, 1997 F250 HD long bed ext cab xlt with a 7.3 Powerstroke. Its in immaculate shape and runs fantastic at 213,000 miles, has a lot of goodies, pac brake, d-cecelerator, built tranny with gear vendor system with 2nd od, trailer brake, hideaway gooseneck, some BEEFY helper springs, Garrett Turbo and more to come. Heres some pictures and will post more when i get home but she will be a work in progress, I will have a lot of pictures!!
Give me some ideas and tell me what you think!
http://i1350.photobucket.com/albums/...ps0085f7b0.png
http://i1350.photobucket.com/albums/...psfc30c626.png
Old 11-19-2013, 02:38 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
cowmilker08 is gaining momentum as a positive member of FTE.cowmilker08 is gaining momentum as a positive member of FTE.
That looks like a really, really nice truck. Where did you buy it? It must have never seen any salt.
As for ideas, start with the simple stuff like Downpipe, exhaust, and a good air filter. You can then build off of that. How you build your truck will depend on what you want to do with it, how much HP you want, and how much money/time you have.
We can help you think through all the options and teach you how to troubleshoot and mod.
Congrats on finding a nice truck!
__________________
-Phil -- Kickin' it OBS
-1996 F-250 7.3L, Auto, 4x4, 3.55 gears, TC lock-up, Amsoil EaAU4095, EBPV gutted, 3" DP, Straight Pipe, 203° T-stat, 1.0 A/R Turbine Housing, 280,000 Miles
-1997 F-250HD 7.3L XCLB 114,000 miles, 3" DP to 4", EBPV gutted, EaAU4095
"He that hath the Son hath life; and he that hath not the Son of God hath not life." 1 John 5:12
Old 11-19-2013, 03:18 PM
7.3fire's Avatar
Thank you verg much! I bought right here in my home town in florida, the only rust on thw teuck is a littlw surface rust on the frame which is normal on any vehicle and up under the front bumper there is a slight bit of surface rust but other than that its rust free! Im going to order the 6637 kit feom riffraff, i want to straight pipe my truck with a new downpipe, what do you guys recommend?
Old 11-19-2013, 04:02 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld has a great reputation on FTE.ReBilld has a great reputation on FTE.ReBilld has a great reputation on FTE.ReBilld has a great reputation on FTE.ReBilld has a great reputation on FTE.
That's one clean rig man! I like the interior. Congrats on the new truck, looks like you got a nice one!
__________________
Bill
'95 F350 CCLB 4x4 dually,ZF 5spd,4.10,Rosewood Stage 2s,T500,S366,IC,Tony Wildman tunes,e-fuel,6637,CCV mod,3.5" DP,Diamond Eye 5" exhaust,Valair clutch,IH water pump,Scangauge,GlowShift gauges
Old 11-19-2013, 04:03 PM
Get a diamond eye system. 3 inch down pipe to either 4 inch or 5 inch exhaust. I like 4 inch personally. Just don't order MBRP. Their kit doesn't fit very well.
__________________
Old 11-19-2013, 05:06 PM
BBslider001's Avatar
BBslider001 BBslider001 is offline
BBslider001 is gaining momentum as a positive member of FTE.
Wow man, nice find!! Enjoy it and stick around here. You'll learn quite a bit and have fun doing it.
__________________
Byron
1997 F-350 CC Dually, 7.3 PSD, 6637 Intake, Straight 4" Stainless Exhaust, 3" DP, Bellowed Uppies and E-Fuel by Re-Billd, Rotella 15w-40/Motorcraft Filters, EDGE Insight CTS, Glow Shift Fuel Pressure/Boost Gauges, John Wood E4OD HD, TS Chip, 217k Miles
2011 34' Sundance by Heartland TT (10,700#)
Old 11-19-2013, 05:17 PM
7.3fire's Avatar
Thanks Guys!! Cant wait to wax her!! I got home from school and took the running boards off, looks 100% better. Next up is a 6637, here are some more random pictures, i will get more of around and inside the truck in a little bit. Also you will see a picture of the air intake if anyone could tell me what kind it is, i dont think its stock.
http://i1350.photobucket.com/albums/...ps4d43209c.jpg
http://i1350.photobucket.com/albums/...ps1d3770ab.jpg
http://i1350.photobucket.com/albums/...pscb3ac245.jpg
http://i1350.photobucket.com/albums/...ps692ce897.jpg
http://i1350.photobucket.com/albums/...psc68263a6.jpg
Old 11-19-2013, 08:03 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is a splendid one to beholdstrokin'_tatsch is a splendid one to beholdstrokin'_tatsch is a splendid one to beholdstrokin'_tatsch is a splendid one to beholdstrokin'_tatsch is a splendid one to beholdstrokin'_tatsch is a splendid one to beholdstrokin'_tatsch is a splendid one to beholdstrokin'_tatsch is a splendid one to behold
Congrats on the new truck.
Just an FYI, the stock turbo is a Garrett turbo if you were trying to imply it has an aftermarket turbo on it.
If it does have a gear vendors double overdrive... They are really great units, but you need to make sure you aren't abusing it too much b/c the cone clutches do wear out fairly quickly if your beating on it all the time. For example, you can shift the OD unit at WOT and it will take it, but it will live longer if your barely touching the throttle for the shift or in manual trans apps, push in the clutch for the shift. One thing to keep in mind with the GV unit, you need to use Mopar synthetic manual transmission fluid and IIRC they want the fluid changed about every 5,000 miles in the OD unit.
__________________
Travis- Death Row Diesel Inmate #7
1995 F-250 RC PSD- because race truck
2000 F-250 SC LB 4x4 ZF6- 4" TB, 6637, TW and Gearhead tunes, 160/100s, Driven Diesel full fuel system, S365..
1994 F-150 4x4
Old 11-19-2013, 08:33 PM
7.3fire's Avatar
Thank you! And this truck has a new turbo, but it is a Garrett, is there a way to tell if it is an upgrade of the stocker? This truck has some cool stuff, i tryed that gear vendor on the way home from getting her, i hit 55mph, let off the throttle completely, hit the button and when the green light came on i went back on the throttle. She shifted just fine, now when slowing to a stop will the gear vendor automatically downshift out of the double od? Thanks for letting me know about the fluid for the od unit, does the gv unit have its own reservoir completely seperate from the tranny pan?
Old 11-19-2013, 10:58 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
You did good, nice ride!
__________________
Glenn The Mule-96 2WD F250 EC/LB auto PSD
The Mare 97 dually cc,modified s366 turbo,stage II's,IC,studs,springs,rods,JW auto,4:10 LS,air bags,SD uvch,efuel,FS2500 bypass oil filter,HVHF IDM,IH WP,6.0 trans cooler & rad fan,MBRP 4",SD tensioner,AFE air filter,220 amp alt,38 gal rear tank & 33 gal aux bed tank,aux oil cooler,soundproofed,3 different TS chips,ac cold mod,XS batteries,riffraff hpop reservoir,aluminum radiator,HoneyBadgerJr hpop, water injection
Old 11-20-2013, 06:25 AM
7.3fire's Avatar
Thank you!
Old 11-20-2013, 06:33 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Yep, truck looks great!
__________________
Darin 99 ranger 76F250 66 fairlane
"TheBeast"1997F2504x4dually4.10's,160k,140VIDM,HPX ,4-5"dp, S366 turbo w/wicked wheel, 6637, elec. fuel,rosewood stage ones,php hydra,arp studs, comp springs, smith brothers push rods, honeybadgerjr hpop,riffraff res,melling lpop,180 tstat,6.0 fan and IC,trucool,coolant filter,scan gauge,lots of other gauges,racer x valve body and billet converter, upgraded trans, F550 leaf springs,SD dual tensioner upgrade, cold ac mod
Old 11-20-2013, 06:37 AM
7.3fire's Avatar
Thank you very much!
Old 11-20-2013, 07:10 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is online now
DIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to all
Congratulations man! Looks like you found a good one! That's a really sharp looking ride.
Get the cruise control recall done though, because it doesn't look to me like it's been done. You don't want your new truck burning up. The Ford dealer can do it in about 5 minutes time and generally they can just do it in the parking lot. You can put the VIN in here and check for any outstanding recalls.
__________________
--Nate "Just a redneck geek"
1997 F-350 7.3 PSD, 4x4, CCLB SRW, 3.55's, ZF5
If it isn't under warranty, I'll fix it myself.
Similar Threads
Thinking of airbags, take a quick survey on suspension upgrades and learn more. WIN GIFT! Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 0 09-18-2013 02:19 PM
Truck U features Torklift: Watch it Here Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 0 09-09-2013 12:52 PM
Try for your chance to win a collector's edition hat! Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 0 09-04-2013 02:08 PM
Talk to me about these numbers and what i should look for sand_fiend 1999 - 2003 7.3L Power Stroke Diesel 5 08-14-2012 08:04 AM
Is this 2008 f350 worth saving???? slddnmatt Super Duty & Heavy Duty 12 03-10-2010 09:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
