6.2L V8 Discuss the 6.2L V8
35in tires
Old 11-19-2013, 01:29 AM
nadieselbogger85's Avatar
nadieselbogger85
nadieselbogger85 is offline
35in tires
recently traded my 05 f150 in on a 14 f250 xl 6.2 with the snow plow package and xlt power group option at least I think what its called. I have been reading on this forum and was wondering if anyone has tried 35s without a leveling kit cause my truck already sits dead level and if I do need a 2.5 level kit, id like to know how many of you are running the drop track bar bracket or if it isn't needed. thanks alot
Old 11-19-2013, 12:50 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
I can't say with certainty as I put a leveling kit on my 350, but there are folks here on FTE (mostly in the 6.7 forum) that have put 35's on a stock truck. I have 35x11.50's and it would probably fit fine without the leveling kit, plenty of clearance.
Didn't Ford put taller blocks on the '14 250's? If so, you could probably get away with a mild leveling kit without the nose being higher than the rear.
Old 11-19-2013, 01:42 PM
nadieselbogger85
My rear block measures 3.5in and truck sits level. How about the drop trac bar bracket if I do go to do a 2.5 level with aal or bigger block in rear
Old 11-19-2013, 03:35 PM
Hotrod70d's Avatar
Hotrod70d
Hotrod70d is offline
i believe you need the bracket or an adjustable rod if you do not want the axel off center. i believe the brackets cheaper . i also agree i believe 35s will fit stock
Old 11-19-2013, 05:13 PM
nadieselbogger85
Thats what I hope the tires fit stock dont want to mess with the suspension on a truck that has 400 mi on it
Old 11-20-2013, 07:07 AM
96sherm's Avatar
96sherm
96sherm is offline
I have 315/70R17 on my 2012 F250, they measure very close to 35". Minor rubbing at full lock left/right on the mud flaps.
Old 11-20-2013, 05:17 PM
miller123p's Avatar
miller123p
miller123p is offline
I have a 2013 F350 short bed crewcab with the plow package and my 35x12.50R20 Toyo MT fit just fine under it. Gives it a great stance to say the least. Enjoy
Old 11-22-2013, 02:25 PM
nadieselbogger85
thanks for the responses guys guess ill try them out my nfab nerf bars came in the mail today so should be a fun weekend
Old 11-25-2013, 10:42 PM
nadieselbogger85
you guys that are running 35s on a stock f250, are any of you running factory molded mudflaps?
Old 11-26-2013, 07:00 AM
nico963's Avatar
nico963
nico963 is offline
You have any pics of the truck?Id like to see it.
Old 11-27-2013, 02:19 PM
nadieselbogger85
Nobody running mudflaps with 35in tires.
Old 11-27-2013, 02:23 PM
2000silverbullet
I do but not the factory ones (Husky's)... You can see they help for about 8-12" back.
Old 12-03-2013, 02:38 PM
nadieselbogger85
Thanks for the pick silverbullet are those 35s with no lift
Old 12-06-2013, 06:12 AM
2000silverbullet
That's 35's with a 2 1/2" leveling kit (front spacer only, factory rear blocks).
Old 12-06-2013, 05:19 PM
nadieselbogger85
Did you do the trac bar drop bracket and problem with steering or death wobble
Quick Reply: 35in tires
