ac bypass pully 351 swap
Old 11-18-2013, 04:28 PM
BigBlueBomb's Avatar
BigBlueBomb
BigBlueBomb is offline
so i am just going to get myself an AC bypass pully to use on my 302 to 351 swap. can i still use the stock bracket then or do i need to get a 351w ac bracket? also going to bypass the air pump as it isnt hooked up to anythign anyways. can i use the same pully kit to bypass that as well? they dont make an "air pump bypass kit" as i am assuming they dont want you taking them off.
Old 11-18-2013, 04:35 PM
danr1's Avatar
danr1
danr1 is offline
Yea you can get it at most any auto parts, trucks not equipped with air (mine for example) had a bracket/idler pulley in the compressors location.
Can buy it pulley only or pulley with the bracket.
mramc1
64
06-23-2021 02:34 PM
droppedf100
05-13-2018 11:36 PM
spacedout
10-24-2005 03:05 PM
fsmartin
06-18-2002 11:36 AM
Quick Reply: ac bypass pully 351 swap
