ac bypass pully 351 swap - Ford Truck Enthusiasts Forums
Old 11-18-2013, 05:28 PM
BigBlueBomb's Avatar
BigBlueBomb BigBlueBomb is offline
BigBlueBomb is starting off with a positive reputation.
so i am just going to get myself an AC bypass pully to use on my 302 to 351 swap. can i still use the stock bracket then or do i need to get a 351w ac bracket? also going to bypass the air pump as it isnt hooked up to anythign anyways. can i use the same pully kit to bypass that as well? they dont make an "air pump bypass kit" as i am assuming they dont want you taking them off.
Old 11-18-2013, 05:35 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Yea you can get it at most any auto parts, trucks not equipped with air (mine for example) had a bracket/idler pulley in the compressors location.
Can buy it pulley only or pulley with the bracket.
my sons 75 Explorer 4x4 with a 390 np435 combo needs a Saginaw pump. which will bolt mofoco1 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-13-2015 04:48 PM
Power steering pump pully snowcat1964 1973 - 1979 F-100 & Larger F-Series Trucks 23 07-20-2014 01:23 PM
Harmonic Balancer Outlaw56 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 0 05-30-2014 12:09 PM
Double Water Pump Pully Outlaw56 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 0 05-23-2014 10:18 AM
Guidance? Power st pump and serpentine removal? Redfridge Explorer, Sport Trac, Mountaineer & Aviator 4 02-10-2014 05:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
