4r100 tailshaft - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
4r100 tailshaft
Old 11-18-2013, 05:07 PM
dhudson06 dhudson06 is offline
dhudson06 is starting off with a positive reputation.
Talking 4r100 tailshaft
i am replacing the output shaft seal on my 2001 4r100 tarnsmission. i pulled tailshaft housing off to replace seal and bushing. when i got housing off i see a rubber doughnut on output shaft. this is on a 2001 ford lightning. i was wondering if anyone knows what this rubber doughnut ( for a better word) is for?... i do not see it on any parts lists
Old 01-15-2014, 04:42 AM
Killer Ride's Avatar
Killer Ride Killer Ride is offline
Killer Ride is starting off with a positive reputation.
Keeps trans fluid in.
Which exhaust doughnut gaskets? MixWizard 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-14-2015 07:31 AM
Tail shaft problem Becauseican1 Clutch, Transmission, Differential, Axle & Transfer Case 0 09-16-2013 01:47 PM
output shaft seal leaking and output shaft housing? woodtrucker Clutch, Transmission, Differential, Axle & Transfer Case 0 07-23-2013 10:39 PM
3 spd toploader tailshaft question? a truck named effy 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-16-2012 08:44 AM
Transmission Output shaft seal bc56845 1999 - 2003 7.3L Power Stroke Diesel 4 02-13-2011 11:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
