brake or bearing our other issue - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-17-2013, 06:23 PM
jes01srw350 jes01srw350 is offline
jes01srw350 is starting off with a positive reputation.
I heard my rear passenger side rotor grinding So I figured it was just the brakes but strange since my rear are newer than the front. Yesterday I put it in reverse and traveled 5 ft then it felt like the brake locked up hard put it drive and it moves freely. Now every time it goes in reverse it locks up either right away our after 5 to 10 ft . Truck has 204k on the original rear bearings, that same side has 1 broken leaf in the leaf spring. Any help is greatly appreciated in advance thank you!
Old 11-17-2013, 07:51 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Could it be your E-brake system? Sometimes things break inside, and cause things to make noise and/or bind up.
Start taking things apart. You'll find the cause.
Pop
Old 11-17-2013, 08:01 PM
Jmatthews's Avatar
Jmatthews Jmatthews is online now
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
Could be one bolt fell off the bracket and the whole thing wedges in the wheel.
Old 11-17-2013, 08:21 PM
I've been told that the e brake needs to be on In order for the diesel heater in the bowl to work it got down to 25 degrees in Dallas the other day so I put it on other than that I don't use it ever for fear that it would freeze up on the rotors. I'll have to check in the bolts tomorrow.
Old 11-17-2013, 09:09 PM
Reckless's Avatar
Reckless Reckless is offline
Reckless is starting off with a positive reputation.
Quote:
That happened to me last year. Sounded just like what's being described. Thought it just a worn pad at first. Plus had one of the brake pads fall apart pushing the pistons against the rotor.
Climb under or better yet pull the tire there and give it a good inspection for such things.
Old 11-17-2013, 09:20 PM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Quote:
Originally Posted by jes01srw350 View Post
I've been told that the e brake needs to be on In order for the diesel heater in the bowl to work...
The story you heard is askew: You need the parking brake on a manual-transmission truck to get the Air Intake Heater to work. The AIH is not needed to run, it's just for improved emissions at idle in cold climates. I live not far from the Canadian border (it gets colder than Texas here), and I yanked that AIH out long ago without issue.
Now... your parking brake is likely seized. There is an actuator lever in there that rusts up something fierce, and setting the parking brake can make it jam. All your brakes are disc, but the parking brake is drum. Sound stupid? Have a look:
Old 11-18-2013, 12:07 AM
clem1226's Avatar
clem1226 clem1226 is offline
clem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to behold
My vote is for this. If the this is what happened and the caliper has worn a groove in the wheel replace the wheel as part of the repair. There was a recent thread in which a member had a wheel seperate at speed on teh freeway with a camper in the bed several years after he had a caliper bolt fall out and the caliper wore a groove in the rim.
Old 11-18-2013, 09:38 PM
Luckily I have my work Truck to drive this week so I can stay safe and tackle this repair this weekend. Thank you all again this site is awesome!
Lift kit on a 79 F150 with Reverse front leaf shrekau 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-11-2014 03:34 AM
nabbed a Trac-Loc at LKQ today 65F1005.8 1968-2013 Full Size Vans 2 12-28-2010 07:58 PM
Front brake keeps seizing help! DansBBF250 1973 - 1979 F-100 & Larger F-Series Trucks 20 06-30-2010 09:45 PM
Need Help...rear leaf spring hitting exhaust billygoat Excursion - King of SUVs 3 03-11-2008 11:34 AM
HELP! Right Rear Wheel Locking up Shedstomper Clutch, Transmission, Differential, Axle & Transfer Case 8 03-15-2004 07:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
