Baldwin BF1212 prepump water separator and freezing conditions - Ford Truck Enthusiasts Forums
Old 11-17-2013, 05:30 AM
90pioneer 90pioneer is offline
90pioneer is starting off with a positive reputation.
Going to be dropping down to 0 and below this week. I have the Strictly Diesel hutch mod kit with a Baldwin prepump fuel/water separator filter installed.
If I happen to get a crappy batch of diesel and it fills up with water, which then freezes, would the filter keep my truck from starting? Or is the filter designed that fuel would still flow? I'm wondering if I should keep a spare filter on hand.
Old 11-17-2013, 06:53 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
When I had a filter there, I kept a spare. My fuel pressure with the big sticks told me the pre-filter was too much restriction.
I changed to this:
Old 11-17-2013, 08:49 AM
CGMKCM's Avatar
CGMKCM CGMKCM is offline
CGMKCM has a good reputation on FTE.CGMKCM has a good reputation on FTE.
The water level would have to fill the outer bowl to block all flow through the filter. I do not think a by-pass is installed or would work.
Old 11-17-2013, 09:57 AM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
Rich, was it the filter causing the restriction or the whole assy?
Old 11-17-2013, 02:12 PM
srteach srteach is offline
srteach is gaining momentum as a positive member of FTE.srteach is gaining momentum as a positive member of FTE.
The water would have to fill the outer area of the filter before fuel would be restricted. You can run isopropyl alcohol (a.k.a. heat and other brand names) to traverse water through the fuel system if you suspect a bad fuel load.
The best bet is to drain the filter / water separator now and anytime you think there is a bad fuel load. I would also keep a spare filter for the "just in case" need.
Don't change it unless you need to because it puts air in the fuel system.
Old 11-17-2013, 05:13 PM
F250_'s Avatar
F250_ F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
If you run a good fuel additive with cold-flow enhancement properties, then you should have no worries about freezing.
Old 11-17-2013, 05:30 PM
Tugly's Avatar
Quote:
I am comfortable in saying it was the filter. The plumbing hardware (except for the filter head) is all the same. The filter head has no restriction to it at such low flows as this.
Old 02-26-2014, 08:47 PM
luvatruck luvatruck is offline
luvatruck is starting off with a positive reputation.
I also installed the same hutch mod kit myself because my fuel bowl was constantly full of junk (mainly sand, rusty etc.). I had gotten a bad tank of fuel. Dropping the tank and cleaning it out did the trick. However, there is still residual crud in my fuel lines even though I have run multiple tanks of fuel. I am convinced that Bio-Diesel is what will cause this to happen. Nonetheless, any time it drops below about 15 degrees, my truck constantly gels up. I have just filled the tank and even put fuel preventative additive in it. I am convinced that the little plastic filter is causing restriction on the tank. More specifically, I think that the reason it is causing restriction is due to a residue from Bio-Diesel and residual crud in the lines. The filter is so small that although the diesel may not freeze, even minimal crud inside that tiny filter is enough to cause restriction. My tuck starts no problem, but will constantly start to gel up after about 10 minutes or less of driving. It also idles fine. I will replace the filter in the spring with the racor unless you guys think my problem is elsewhere.
Old 02-26-2014, 09:11 PM
My father has the baldwin in his 02 F250 (I installed it). He hauls RVs to dealers from the factory and has had many problems with it, mainly when it is -10F and lower. He also has to fill up in many different locations across the country and cannot know how each stop keeps their tanks.
I've had my Baldwin 1212 in longer than he has and never had a problem. There is a new filter there now because of other issues (it was a troubleshooting step), but there is a water / crud filter there.
Old 02-26-2014, 09:16 PM
I plan on putting all my filters in a box under the bed. I have a coolant and pre-pump fuel, I plan on adding a bypass oil and trans filter in an under bed box. I will do a write up when I do it for the truck in my sig.
Box will hang just in front of the wheels, behind the cab.
Pre-pump filter options carguy3j 1999 - 2003 7.3L Power Stroke Diesel 40 09-20-2016 09:57 AM
Hutch- how often do you change filter? Jointasset 1999 - 2003 7.3L Power Stroke Diesel 6 03-13-2016 10:18 AM
How often to change pre-pump strictly diesel water/fuel separator filter? 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 3 11-03-2013 09:23 PM
Hutch mod - filter change interval BWST 1999 - 2003 7.3L Power Stroke Diesel 10 01-10-2013 11:14 AM
Pre-Pump Filtration - Questions re Best Practices F250_ 1999 - 2003 7.3L Power Stroke Diesel 25 01-01-2012 08:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
