BRAKES? - Ford Truck Enthusiasts Forums
BRAKES?
Old 11-16-2013, 11:54 PM
MAN_N_BLACK MAN_N_BLACK is offline
MAN_N_BLACK is starting off with a positive reputation.
BRAKES?
im trying to figure out which way I want to go I have brake pedal from a ranger that I think would work booster and all or I have the setup from the 95 f150 I got. or I was thinking on just buying one of these kits
as of right now there is nothing
was wandering what the pros and cons of the kit would be im thinking on gong disc /disc but not 100% on that yet I do plan on pulling a trailer with this truck so that's a factor too
Old 11-17-2013, 12:45 AM
smallello's Avatar
smallello smallello is offline
smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.
I used this set-up:
This my install: It mounts on the rib on the firewall so the booster is not over the engine. The PO had it right above the valve cover.
Old 11-17-2013, 02:00 AM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
You should take a look at the on-line catalog for Engineered Components. They have a firewall mounted package as well.
Dan
2002 f150 3 inch lift bronco6767 1997 - 2003 F150 1 10-11-2015 10:51 PM
My first F1 is for sale Ha Cody_1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-25-2014 06:22 PM
1948-52 brake booster info Rimrock F1 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 07-01-2014 02:59 PM
Power Chip Suprawill1 Escape & Escape Hybrid 2 12-05-2013 01:17 PM
Brake power booster and master cylinder in an F1 51PanelMan 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 10-15-2013 06:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
