frame bracket help
frame bracket help
hey guys im having problems replacing my cab mount frame brackets so i guess im going to have to fix them...anyone know the measurement from the rad core support frame holes to the front cab frame mount holes? center to center? i have the big washers from jbg but i need to know where to weld em up at!
ty
ty
I'm a bit befuddled..... Can't you measure the opposite side to get the required measurement? I mean, it's a mirror image.
Don't tell us that no measurements were taken before commencing with this work! That would be an epic fail.
I assume you have a cab. Why not measure on-center from the rear cab mount to the front cab mount?
Its a michigan truck where the bushings sit on the front and rear frame mounts for the cab is rotted out so i have no where to start except the only 2 good holes at the core support.i can measure my cab but that wont tell me where to put the cab on the frame, only where front and rear cab mounts are in relation to each other....
Its a michigan truck where the bushings sit on the front and rear frame mounts for the cab is rotted out so i have no where to start except the only 2 good holes at the core support. i can measure my cab but that wont tell me where to put the cab on the frame, only where front and rear cab mounts are in relation to each other....
Okay, search through this: 1976 Ford Body Builder's Layout Book - FORDification.net
Much luck to ya man.
flash back 100 hope this helps
Here we sell is the front cab mounts that are rivoted to the frame of the truck for 1965-72 F-100/250/350 Trucks 2 wheel drive ++ have other years in stock They sell for 130.00 for the pair and are checked for cancer etc... +++ we have them for other years also as well if looking for other years as well
ford-harto3457
04-05-2009 12:53 AM
