help! O ring seal for oil cooler housing - Ford Truck Enthusiasts Forums
Picture competitions Ford truck picture competitions, voted by you!
Old 11-15-2013, 08:09 PM
blueeyedfordguy's Avatar
blueeyedfordguy blueeyedfordguy is offline
blueeyedfordguy is starting off with a positive reputation.
2000 vw beetle, oil cooler housing o ring failed. Massive oil pressurized leak. Looked up part at auto zone and advanced auto. Victor reinz B32300 and B32299. Is there a difference between the two??? Auto parts man says yes. Websites say no the two are the same fit and dimensions but different quality.
* can I remove the seal and find an after market o ring that's the same size to fit?
* people online say the oil filter for this car has an o ring that fits perfectly. Should I even try that ?
Thank you much
460 engine oil filter adapter seal/O-ring part numbers redmondjp 1987 - 1996 F150 & Larger F-Series Trucks 0 08-27-2016 10:12 PM
New Oil Cooler Leak!! Texasdeereandhorse 1994.5 - 1997 7.3L Power Stroke Diesel 2 06-30-2016 11:42 AM
2015 Coyote engine repowers. fbb1951 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 12-02-2015 01:38 PM
Bulletproof Diesel Oil Cooler INSTALL -Snake- 6.0L Power Stroke Diesel 46 11-06-2012 05:33 PM
Getting brave CR3999 6.0L Power Stroke Diesel 3 08-02-2012 08:27 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
