5.4 plugs round 2 - Ford Truck Enthusiasts Forums
5.4 plugs round 2
Old 11-15-2013, 06:38 PM
vpsr6 vpsr6 is offline
vpsr6 is starting off with a positive reputation.
5.4 plugs round 2
I was looking to see if anyone has changed plugs for the 2nd time on the 5.4.
I have an 05 5.4 xlt 4wd and changed mine without issue at 30k and I am now approaching 100k and was going to replace them again with the new 1 piece plug. With the nickel anti seize as outlined on the TSB will the plugs come right out or is it recommended to do it like he first time.
thanks
Vic
Old 11-16-2013, 11:07 AM
Varsity Tyler Varsity Tyler is offline
Varsity Tyler is starting off with a positive reputation.
It's still a crap shoot. The problem wasn't truly a two-piece plug, it was the fact that the extended electrode housing went into its own bore on top of the combustion chamber. The anti-seize can't hurt, but it's not guaranteed to help, either.
Carbon is still going to get in that bore and try to seize the housing to the bore. My advice is to soak the plug wells with Motorcraft Tune-Up Cleaner and leave it overnight. The stuff does wick down and do a decent job of lubricating that electrode housing.
Good luck, and remember to change the oil afterward as well.
Old 11-21-2013, 10:16 AM
Okiedokie's Avatar
Okiedokie Okiedokie is offline
Okiedokie is starting off with a positive reputation.
My 2000 F150 has a different plug problem but I was recently discussing the two piece plug problem [my son has a 2007] with a friend who runs his own repair shop, and has done many of these. He commented that the bad thing about the one piece plugs is that if they seize in the hole they will not come apart, but almost certainly damage the head. Repair cost will increase greatly. I have no personal experience with either.
Old 12-26-2013, 08:50 PM
Someone had do this for the second time? I will most likely follow the TSB as I did the first time, I am just wondering if the nickel anti-seize actually did anything as far as preventing the carbon build up.
thanks
Vic
Old 12-28-2013, 06:59 PM
Golflug's Avatar
Golflug Golflug is offline
Golflug is starting off with a positive reputation.
I did mine originally at 30k and they all came out without any issues in one complete piece. I followed ALL of the tsb recomendations to the letter and used the high temp Nickle antiseize. Now as I approched 100k I decided to change them again. I followed all of the same procedures as the first time, but this time 6 of the 8 broke off and I needed to use the removal tool to get them out. The antiseize did nothing IMHO.
Old 12-28-2013, 09:20 PM
Thanks for the reply, I am in a similar mileage situation having changed them first time around 30k and now approaching 100k as I plan on keeping the truck much longer I wanted to do them again. That really sucks about the anti seize doing nothing, I think it was wishful thinking on fords part. I to had no issue the first time so I will just follow the procedure again and see what happens although I assume I will not have to do it again after this at least the new plug design will help if I have to.
Old 12-28-2013, 11:53 PM
Agent Smith's Avatar
Agent Smith Agent Smith is offline
Agent Smith is starting off with a positive reputation.
I change mine every 30k to avoid the bs from broke plugs
5.4 2v broken spark plug Borgia 1999 to 2016 Super Duty 9 09-30-2016 10:14 PM
2009+ 5.4 spark plugs. Same 2 piece? When to change? Paulford8 2009 - 2014 F150 27 09-29-2016 08:11 AM
Changing spark plugs on 2008 5.4L Platinum08 Modular V8 (4.6L, 5.4L) 2 07-06-2014 05:24 AM
5.4L spark plugs gogreenwave 1997-2006 Expedition & Navigator 11 02-27-2014 09:53 AM
Worried about changing 10 yr old plugs - 5.4L F150 PEG 1997 - 2003 F150 7 02-21-2011 06:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
