Dummy EGR? - Ford Truck Enthusiasts Forums
Dummy EGR?
Old 11-15-2013, 07:29 PM
pile_53574 pile_53574 is offline
pile_53574 is starting off with a positive reputation.
Question Dummy EGR?
Does anyone make a dummy EGR valve, one you can plug in, not operate and not throw a code?? Maybe its invention time!!
Old 11-15-2013, 07:54 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
its called a programer
Old 11-15-2013, 07:58 PM
jswartz84's Avatar
jswartz84 jswartz84 is offline
jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.
Quote:
Most of us leave the egr valve in place and plugged in for proper cooling fan operation.
Old 11-15-2013, 08:05 PM
Quote:
Right, already have programmer, but does not shut off egr, so wondering if something else was available
Old 11-15-2013, 08:47 PM
Unrealo4's Avatar
Unrealo4 Unrealo4 is offline
Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.
Custom tunes by matt @ gearhead. All his tunes include egr being turned off by default.
Old 11-15-2013, 08:51 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
What tuner do you have?
Old 11-15-2013, 09:44 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Probably only looking at commanded EGR and not EGR error which would show -100% even though the commanded opening would for example be 28%
Josh
Old 11-15-2013, 10:03 PM
w_huisman's Avatar
w_huisman w_huisman is offline
w_huisman has a good reputation on FTE.w_huisman has a good reputation on FTE.
Ford 6 0 Diesel EGR Eliminator Spool w Clamps Bolts | eBay
Is this what you're looking for? I run with one, and leave the actual EGR valve plugged in and bolted to one of the intake elbow bolts.
Old 11-16-2013, 07:45 AM
Yes, so EGR is still plugged in, but sitting on outside of motor still functional?? I knew someone would come up with this. Good price too. Thanks
Old 11-16-2013, 12:14 PM
cheezit's Avatar
sct should give the option. mine does
Old 11-16-2013, 05:05 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
So you're going to just plug the hole for the valve? You're going to not address the actual problem which is the EGR cooler itself, or delete any of the components that have exhaust gas flowing through them, and instead shove the plug in the hole and leave the valve sitting out in the engine bay?
If you don't have inspections, why not just spend $40 more delete with a kit, or even less $ to weld up the cooler that's already in there, then you don't need the plug because there's no gas flow.
If you do have inspection, you're going to be pulling the plug to reinstall the valve annually anyways, why not weld the cooler and leave the valve in place?
Any way you cut it, you'll need a programmer that can kill the CEL or you'll have to buy a PCM flash from someone because simply removing the valve won't stop if from setting a P0401 insufficient EGR flow code.
Old 11-16-2013, 05:10 PM
Bullitt390's Avatar
You can lead a dumb horse to water, but ya can't make him drink
Josh
need your thoughts guys! grovey 6.0L Power Stroke Diesel 7 04-29-2016 10:45 PM
upgrading oil and egr cooler oughtsixbigred 6.0L Power Stroke Diesel 8 05-17-2015 05:58 PM
EGR delete Furr308 1978 - 1996 Big Bronco 12 03-30-2015 06:23 PM
pullin hard relayman53 6.0L Power Stroke Diesel 7 05-21-2014 06:44 PM
egr delete/p0401 ballbandit 6.0L Power Stroke Diesel 7 05-22-2013 08:52 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
