Airbag removal 2000 Ranger - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-14-2013, 07:27 PM
maytag906's Avatar
maytag906 maytag906 is offline
maytag906 is gaining momentum as a positive member of FTE.
The cruise control switch on my 2000 Ranger just broke. It looks like you have to remove the airbag to access it. How is that accessed? It looks like there are 2 plugs on the back of the wheel that need to be removed.
Any tips?
Old 11-14-2013, 09:05 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Some information on cruise pod removal/modification can be found HERE.
Old 11-15-2013, 06:37 AM
maytag906's Avatar
Thanks, that was very helpful!
Old 11-15-2013, 11:18 AM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Isn't that something, my 99 switch pod just broke also. Was pushing the Off switch & pushed too hard I guess. That danged switch always had required a firmer that normal push to turn the cruise on or off. Anyway will be interesting to hear how it goes & any tips you might come up with.
When working with the airbag, since its static electricity time of year, make sure your grounded good to the vehicle chassis while your working the airbag & squirming around in the seat & sliding your feet on the carpet!!!!! Don't want a static discharge to set that puppy off!!!!
Nice link on the cruise control switch pods Rockledge, I like pictures, saved it to my Ranger file.
Old 11-15-2013, 02:54 PM
maytag906's Avatar
Well, I went to the boneyard, and for $20 bux, I pilfered the switches from a 99 Explorer. The cruise situation is now repaired!
Put new shoes and hardware on the rear brakes, backed it out of the garage, and promptly blew a front brake line!
Somedays ya just can't win....
Old 11-15-2013, 07:20 PM
Better that the brake line blew in the driveway than when stopping in traffic.
Good to hear the cruise switches are replaced, any problems to look out for, or tips to offer???? Haven't dug into mine yet, but gotta get it done by months end, along with trouble shooting the dang anti-lock brakes as I was driving it to check that system out by engaging the cruise to see if it was working ok & if not I'd first be looking at a rear speed sensor problem & thats when I pushed on the cruise Off switch & it broke. Like, you when it rains it pours & the last two weeks its been pouring with my vehicles, no problems all year long & the last two weeks its one dang thing after another!!!! We'll just have to knock em down one at a time & just keep on keeping on!!!! lol
Old 11-16-2013, 07:52 AM
maytag906's Avatar
It was pretty straight forward. One thing to watch is the ribbon connectors on the switches, they pull straight off. I had a problem at the yard getting them off, I cut the wire, and then examined them. They can be attached pretty tight!
Old 11-16-2013, 10:38 AM
OK, thanks for the feedback tip on the switch flex circuit connectors.
I assume the air bag comes out as a module assy, by removing the two fastners behind the plastic cover plugs on either side of the steering wheel???? My manual isn't real clear on that proceedure.
The link Rockledge posted sure helped clear the air on what the cruise control switch modules look like & how they are mounted.
As you said, it seems that once you get to them its a fairly straight forward replacement.
My right side controls are ok & have always operated easily as they should, so no problem with them.
I think my left side on/off switch screw tangs have broken off, as its always required extra hard pushing to turn the cruise on/off there, so something inside has probably never been right & nearly 14 years for the plastic mounting tabs to bake out has probably made it brittle too.
Now off to locate a replacement on/off switch module without having to bring my banker along!!!! lol
Old 11-16-2013, 04:08 PM
maytag906's Avatar
Yeah, airbag comes out in 1 piece. The left side switches on mine broke the tabs, the right side broke 1 tab.
Try the Pik a Part, or I've seen them on EBay, for $20-$50.00.
Old 11-16-2013, 04:32 PM
OK, so it looks like they are easier to get at than find. Have found the complete wiring assy which includes both switches, but the prices are absurd, $80-$150 & all I need is a $2 switch, so looks like the salvage yard is about to get a visit. Heck I've already wasted more time searching on line than it would take to go to the salvage yard, pull & install the danged part. Now the danged weather is messing with me, so gotta work around that too!!!! No rest for the Wicked!!!! lol
Air bag DIY Replacment 007ROADSTER Ranger & B-Series 15 02-01-2016 05:37 PM
How to Remove Airbag for Bad Airbag Clock Spring? dgruhlke 2007 - 2014 Expedition & Navigator 0 10-29-2014 09:46 PM
1998 airbag problems Jacob Ripley Ranger & B-Series 5 01-11-2014 02:37 PM
Airbag Warning Light Stays On megaede 1999 - 2003 7.3L Power Stroke Diesel 3 11-04-2010 09:22 PM
Airbag chimes Red Monkey 1999 - 2003 7.3L Power Stroke Diesel 8 10-01-2008 07:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
