7.5 inch rear end: u-joint yoke to pinion flange bolt torque spec
Old 11-17-2013, 12:18 AM
Dalek Sec's Avatar
Dalek Sec
Dalek Sec is offline
I'm working on getting a factory manual for my 99 Ranger, but in the meantime I could really use the torque spec for the 4 bolts that attach the drive shaft to the flange on the pinion shaft. The bolts with the 12-point heads--not the giant nut that holds the flange on the pinion shaft.
I'll be your best friend if you can look that up for me.
1999 Ranger. 7.5 inch rear end.
Old 11-17-2013, 03:59 AM
03 Maz B23's Avatar
03 Maz B23
03 Maz B23 is offline
CommanderCrzy
06-08-2015 01:48 PM
cfvwd
2004 - 2008 F150
12-23-2012 03:01 PM
GNR22
06-19-2012 04:43 PM
cdwoodcox
10-09-2011 04:26 PM
Brent M.
Escape & Escape Hybrid
12-22-2006 12:46 PM
Quick Reply: 7.5 inch rear end: u-joint yoke to pinion flange bolt torque spec
