Urgent help needed!!!
Old 11-14-2013, 06:02 PM
joshbea6's Avatar
joshbea6
joshbea6 is offline
Exclamation Urgent help needed!!!
Vehicle 2007 Ford Explorer Sport Trac with 4.6L
Ok, just did a head gasket replacement. Everything is now hooked back up. Now when we try to restart the car, we get lights, but nothing from the starter. Also the OBDII code puller can't communicate with the car. Also the security light flashes very fast when you try to start.
Does ANYONE have ANY ideas? PLEASE HELP!
Old 11-14-2013, 07:35 PM
Graygeorge's Avatar
Graygeorge
Graygeorge is offline
I would check all ground wiring.
Old 11-14-2013, 09:24 PM
joshbea6's Avatar
joshbea6
joshbea6 is offline
I never disturbed any of the ground wires.
Any other suggestions?
My biggest baffle is why the OBDII code scanner won't communicate.
Old 11-14-2013, 09:31 PM
Mikeman's Avatar
Mikeman
Mikeman is offline
The only suggestion I have is from when I replaced the engine in my Honda and couldn't get it started. I found a connector that wasn't all the way seated. Double check all your connectors.
Old 11-14-2013, 11:11 PM
shorod's Avatar
shorod
shorod is offline
I'd suggest you check all fuses and fusible links to see if any are burned. Maybe a wire got pinched when reassembling.
-Rod
Old 11-14-2013, 11:18 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
I'm on board with the wiring being the problem . Loose ground , they are everywhere , connector not fully seated , fuse , etc.
Old 11-15-2013, 08:00 AM
joshbea6's Avatar
joshbea6
joshbea6 is offline
One other thing that I noticed late last night was that the security light on the dash is blinking very rapidly.
Got off the phone with the stealership this morning and they said that the PCM may need re-flashed.
Does this sound like something that could possibly be?
Old 11-15-2013, 06:25 PM
shorod's Avatar
shorod
shorod is offline
The flashing Security light when trying to start it often indicates that the PATS/SecuriLock systems does not recognize the key. If you have another programmed key for the Explorer, try it, by itself, with no other transponder keys nearby.
If you did not change the PCM or the PATS modules out during this process, I would not expect the PCM to need to be reflashed.
-Rod.
Old 11-18-2013, 07:14 AM
joshbea6's Avatar
joshbea6
joshbea6 is offline
Nothing outside of Head Gaskets were changed. I did have to remove the computer module from the body of the vehicle so that I could get to the back bolts on the head, but it is the same one that was in it to begin with.
Old 08-11-2014, 12:57 PM
big1cwboy's Avatar
big1cwboy
big1cwboy is offline
your computer probly lost every thing due to lose power from battery and now nothing works am guessing here just a ideal I always hook a 9 volt battery to one of the power *** be for unhooking the battey just to power the computer
Lucas Frink
1978 - 1996 Big Bronco
07-01-2019 09:04 PM
blue66tang95f150
01-11-2017 09:55 PM
jamesoncue
02-12-2012 01:09 PM
dmalo810
1997-2006 Expedition & Navigator
06-02-2009 07:48 PM
shaggymane
General Automotive Discussion
22
11-17-2004 11:46 PM
Quick Reply: Urgent help needed!!!
