Is 4x4 really 4x4? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Is 4x4 really 4x4?
Old 11-14-2013, 03:18 PM
Granpa's76 Granpa's76 is offline
Granpa's76 is starting off with a positive reputation.
Is 4x4 really 4x4?
I am new to Rangers, and am looking at a nice 2003 FX4 4x4. Many years ago I had a Nissan that claimed to be 4x4 but clearly wasn't. How are these things setup, is it a true 4x4 when needed?
Old 11-14-2013, 06:52 PM
F0rdFre@K's Avatar
F0rdFre@K F0rdFre@K is offline
F0rdFre@K has a good reputation on FTE.F0rdFre@K has a good reputation on FTE.
Unless it's got lockers front and rear, nothing is "true" 4x4. Best option from the factory would be a limited slip differential (you'd need to decode the tag on the axles to know for sure) But, any open carrier will lose traction if you twist your body and have 2 wheels in contact w/ the ground and 2 up. the 2 up will get power while the 2 on the ground get sheeite!!! Frusterating... But, that's what makes a differential a differential.
Old 11-14-2013, 07:03 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
It's more 4x4 than a two-wheel drive.
Old 11-14-2013, 08:21 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
All 2003 FX4 Rangers have some sort of LSD. And they all have 4.10:1 gears.
2003-up FX4 Rangers have the regular Ford "TracLoc" limited-slip (28 spline).
2003-up FX4 Level II Rangers have the "Torsen" limited slip (31 spline).
Old 11-15-2013, 10:17 AM
F0rdFre@K's Avatar
Quote:
Until you twist your chassis... then it's no wheel drive...
It doesn't mean the truck is completely useless. Remember this bit of information and drive accordingly. If you plan a lift, get a lift that offers a good amount of flex so it'll be much harder to twist the chassis to the point you lose traction on the two wheels. Also, carry a high lift jack or a buddy with a tow rope.
Old 11-15-2013, 10:43 AM
It's a level II, with 50K miles, looks almost showroom perfect. Sounds like a good base for a fun wheeling/hunting rig.
Need Help With Some ID'ing Please Bamadawg63 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-01-2015 10:40 AM
1987 f150 build thread steve33444 1987 - 1996 F150 & Larger F-Series Trucks 2 09-29-2014 01:55 PM
Slow turn signals Granpa's76 1973 - 1979 F-100 & Larger F-Series Trucks 10 10-04-2013 12:10 AM
Holley fuel pressure bracket Granpa's76 1973 - 1979 F-100 & Larger F-Series Trucks 0 08-23-2013 09:45 PM
Bumper swaps Granpa's76 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-12-2013 08:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
