Road Trip Issues
Road Trip Issues
Hi All. To give a bit of history, 06 f350 6.0. Completed a ton of work after a P2290.
The original problem was loss of power when warm, stall but starts.
Then I proceded to change:
-stand pipes
-dummies
-stc fitting and o rings under hpop
-irp o rings and screen (old screen was clean)
-All 8 injector seals
Test drove foe 50 miles and every thing seemed GREAT. Peddle down icp went to 3600 psi, eot and coolant temps good, smooth running lots of power.
Yesterday started a 1000 mile road trip.
50 miles into road trip the air pipe to intercooler blew off, freaked me out, re installed and on my way. I figure that was the one glitch... NOT!!
125 miles into trip engine light and a P2290, , ICP would not go above 1800, IRP would hit 84.7 with ease, loss of power but still drivable.
another 30 miles down the road it got worse, less power, icp not going past 950, and just about stalling at a couple construction stops.. IRP almost always at 84.7
Realise I am in the middle of no where and since I am still running and motor temps are ok I decided to just keep going rather then turning around. If it dies .. Well ill just get it towed.
I had a full tank of fuel so I just kept driving.
Stopped at the 600 mile mark to get fuel and food. 15 min stop. Started up and a way we go, OK running a bit better, ICP going back up to about 1800 and IRP not going up to 84.7 as easy.
Stopped at 800 mile mark. 15 min stop. Started up and took off like a jack rabbit. ICP going up to 3500 when foot into it, irp only hitting 84.7 when rpms up and peddle down.
Ran great for the rest of the trip.
WTF.... Think I'll name her Christine..
-stand pipes
-dummies
A P2290 means that your ICP is under ICP desired for "x" amount of time, and I can see that with what you describe. I'm thinking bad ICP sensor (or pigtail) or IPR valve issues since your HPOP is putting out 3500+. It's just difficult without being able to watch it. You could also have collected some trash on the new IPR screen....
A graph of ICP, ICP desired, ICPv and IPR. You should be able to graph and log all 4 at the same time. At some point you'll see ICP desired above the ICP actual for an "extended" period and the P2290 will set. I don't remember the exact time that it takes to set the code, but it's not long. Certain tunes will also set the code if the ICP desired is above what the HPOP is capable of and you'll have nothing mechanically wrong with the truck.
Ill give it a try. I have cleared my code and took the truck for a short drive. No Issues.
??? Would it be fair to assume, given the issues I had yesterday, that it will be a electrical / sensor issue rather then a oil leak.
I just don't see if it was a oil leak or bypass causing the preasure to go down, how it could stop leaking in the middle of a long road trip.
Is there a hydraulic schematic of the HPO system??
I think I need to understand, Exactly how this system works, communicates etc.
Starting at page 27 here: Powerstroke 6.0L Technical Intro Manual. AFA how it communicates it's PCM programmed and a little bit complex.
Yes, I think your problem is electrical, at least that's where I'd start.
Ok, Been doing some reading. I do have a very good understanding of hydraulic systems. This seems to be a simple system, but wthout knowing exactly what the PCM is thinking, determining if the ICP is faulty or the IPR is faulty becomes a bit confusing.
• The ICP sensor is a three (3) wire
variable capacitance sensor.
• The PCM supplies a 5 volt
reference signal which the ICP
sensor uses to produce a linear
analog voltage that indicates
pressure.
• The primary function of the ICP
sensor is to provide a feedback
signal to the PCM indicating ICP.
• The PCM monitors ICP as the
engine is operating to modulate the
IPR. This is a closed loop function
which means the PCM continuously
monitors and adjusts for ideal ICP
determined by conditions such as
load, speed, and temperature.
• The PCM monitors the ICP signal to
determine if the performance of the
hydraulic system is satisfactory.
• During engine operation, if the PCM
recognizes that the ICP signal is
lower or higher than the value the
IPR is trying to achieve the PCM
will set a Diagnostic Trouble Code
(DTC) and illuminate the amber
malfunction indicator lamp on the
dash.
• The ICP signal from the PCM is one
of the signals the FICM uses to
command the correct injection
timing.
The IPR (Injector Pressure Regulator) is a
duty cycle controlled valve that the PCM
uses to control ICP (Injection Control
Pressure).
• The IPR is a valve that blocks the path to
drain for oil coming out from high pressure
pump. As duty cycle signal increases at the
IPR the restriction to drain increases, thus
increasing ICP.
• When the valve is disconnected it is in its
open or drain state and the engine should
not start.
• The IPR valve also contains the pressure
relief valve for the high pressure oil system.
Ok The ICP sends the PCM the actual preasure in the system.
The PCM sends a command to the IRP to open and close to maintain a desired preasure by dumping oil to resivoir.
The IRP also sends a signal to PCM with its actual position, Right??
This is the % value that displays on my scanguage, Right??
The IRP value, 84.7% means 84.7% closed since the valve is normally open position.
I assume that since the valve is normally OPEN ( at 0%) and the max closed value being 84.7%, that the valve cannot completely close ?? Right??
Say for example, the system has a oil leak (bad dummy plug) a greater volume of oil will be required to maintain proper operating preasure, Thus the PCM should send a signal to the IRP to close ( a higher % value) reducing the oil dumping to resivoir,, compensating for the leak and still achieving proper preasure to run. A bad leak would result in the IRP closed to its max (84.7%) and allowing minimal oil back to resivoir and still not maintaining preasure. Result would be crank, no start
I have changed all HPO system seals except for oil rail seals and believe that I do Not have a leak, And since most of the time im able to build system preasure to 3500.
Then shut truck off for a min or drive for a mile or two then all of a sudden IRP reads 84.7 and it stalls at a traffic light. Starts up right away and back to normal.
I believe the ICP is sending the correct signal to PCM as I am monitoring it constantly, and the behavior of the motor seems to follow the ICP.
I think the problem is between the PCM and the IRP. The IRP is giving feedback to the PCM as to its Position,
But the correct signal (Voltage) the PCM is sending the IRP seems to be screwed up.
Does any of this make sense, or am I barking up the wrong tree??
pressure.
dash.
timing.
Pressure).
increasing ICP.
not start.
on
After doing a lot of reading, I am convinced that the issue is the IRP or IRP pigtail.
The PCM is obviously sending a signal to IRP to close to adjust to reach desired PSI.
I believe that the IRP is NOT responding to the commands, RE. Staying open.
The only question, is it a pigtail / wire issue or is it a sticking IRP.
One must be able to diagnos this...
Is the pigtail to the IRP a OEM item ??
