people that have gone with 51-52 front fiberglass fenders
what if anything do you need from the originals? Just the inner bracing?
I can't tell from the pictures if the lip under the front inner corners by the headlights is part of the fiberglass fenders or not.
anything else I am missing?
They're not plug and play. You'll probably spend the same, if not more, time fitting, drilling, adjusting, etc., glass fenders then you would spend on steel.
Back to your question. You'll need the headlight bucket panel, core support brace and rear filler for the running board area.
Zero rust repair = more $$ than fiberglass. Have fun with fiberglass! They're not plug and play. You'll probably spend the same, if not more, time fitting, drilling, adjusting, etc., glass fenders then you would spend on steel. Back to your question. You'll need the headlight bucket panel, core support brace and rear filler for the running board area.
Thanks for the answers
We put fiberglass front fenders on Jon's 50 and I fully admit that they were a bloody pain in the rear. Nothing fit perfectly, it was close but the small waffles at the seam lines looked like hell so we spent mega hours sanding them to fit the body true and flat. Then the upper and lower halves didn't mate up either so we finally bonded them together into one piece fenders (which looks better anyway).
To sum it up, we put in three to four times the man hours fitting the fenders than it would have taken to flush patch all the rust on the originals.
The only reason we went to fiberglass was to be able to re contour the wheel well opening to the shape and size that Jon wanted.
Fiberglass Front Fenders
I would like to add my 2 cents to the fiberglass issue. I had two used front ones made by Fairlane Ford for my 1950 F-1 which were supposed to be one of the best. They fit fine until I got to adding the last piece (upper hood panel) and there was a gap if about 5/8 inch on either side. No matter what I did I couldn't close the gap and I stopped when the fiberglass started cracking when I continued tightening the bolts
I have one fairly good steel one but will now be looking for a good used left one.
Wonder if anyone has had good luck with fiberglass front fenders??
I put fiberglas fenders on my 50 f1.The only issue I had, was that the previous owner had removed the brace at the top of the core support, that let the whole front clip "spraddle out", once I got the front fenders pulled back to where they should be, everything fit good. The actual fenders were better than the originals. I'm sattisfied with what I got at this point. Good luck with your project.
Hey Ryan,
We went with fiberglass - saving months of welding, grinding, & sanding.
It wasn't plug & play as there is definitely some sanding to get the gaps right. The fenders on these trucks are so huge & visible it's nice to have smooth new fenders. No complaints here & no rust.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
