Here it is boys! My new shop toy!
That's the vertical adapter. Changes it from a horizontal mill to a vertical mill.
Started taking it apart yesterday after the crap with the old renter stopped work on the rental house. Got it about half torn apart and the parts in the hot tank. I did find a couple screwed up bevel gears under the table. I wil have to weld them up and grind/file new teeth on them. Pain in the butt, but with a 100 year old mill, I expected some problems, and I can fix it...
Here are some more pics of the teardown. The next to the last pic is the two small bevel gears that will have to be fixed, and the last pic is the huge shaft in the lathe ready to be polished. All the parts we took off yesterday are in the hot tank now!
Those are the gears for the main bed (X axis) power feed. The Y and Z axis drives still work. I'll weld up the gear face and use the die grinder and file to repair the broken teeth. I've done it before. Not a "nice" job to do but with a little time I can get them working again.
Received 5,160 Likes
on
#28
Well thank you and good evening Gerry! I spent years doing stuff like this to keep farms and mines running. Like I said, not a fun job, but one i'm not afraid to do...
I might even post some pics of the process. I'll heat treat the gears when I have the new teeth where I want them. There is enough remaining teeth to make a metal pattern that I'll use to get the shape right. Tedious, but doable!
#29
on
#30
