any help will do - Ford Truck Enthusiasts Forums
any help will do
Old 11-13-2013, 12:31 AM
tattooed_yoshi's Avatar
tattooed_yoshi tattooed_yoshi is offline
tattooed_yoshi is starting off with a positive reputation.
Exclamation any help will do
ive got a 1996 f150 4.9l thats throwing me p0171 and p0174 codes now ive rebuilt the motor replaced the gaskets smoked the vacume lines and have no leaks anywhere i replaced the egr and the egr vacume sensor. i did a fuel pressure test and am right on the money. the light will not go away unless i run a 97 octaine mixture and when i do that i throw no codes and have no problems untill i run out of gas and then i get my bank 1 & bank 2 lean codes. one thing i did notice is that i have an air charger sensor on my lower intake but ive looked at the harness and there is no plug or cut/melted off lines its just there any help or advice will do. like i said i rebuilt the motor to fix this problem every gasket and sensor is new and good and every bolt is torqued down to spec. the pic is the sensor that has no conector
Old 11-13-2013, 07:22 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Ford moved the ACT sensor to the air filter box around 1994. If your truck has a ACT in the manifold then it came from an earlier model. Since you have no codes indicating a problem with the ACT then I would assume the wires are connected to the air box mounted ACT sensor.
You have started several threads about this issue, I pointed out in this one: http://www.ford-trucks.com/forums/12...s-for-day.html that a dirty or faulty MAF could be the cause of the lean codes. As suggested before low fuel pressure could also contribute to the problem. What were the fuel pressure values when you tested it?
Old 11-13-2013, 04:45 PM
I clean the MAF sensor and on the obd2 it was reading just fine I also did the fuel pressure and it's coming out at 52 psi rear tank and 51 psi front tank I replace well you seen the other threads ive replaced mostly everything else and the fuel pressure regulator is also fine so I don't know what else it could be besides possibly the injectors I also appreciate your ongoing help with this matter
Old 11-14-2013, 07:51 AM
rla2005's Avatar
Quote:
Were those pressures ever measured with the engine running and under load? It would be rare to have two weak pumps but I do not recall if you changed the fuel filter.
Old 11-14-2013, 09:50 AM
Bob Gervais's Avatar
Bob Gervais Bob Gervais is offline
Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.
What brand spark plugs are you running?
In addition, and I'm not trying to be an *** here, but it's MUCH easier to keep just one thread going per issue you're having. Lots of people (me included), won't take the time or effort to search out other threads you may have posted. Lots of times, that results in people who recommend things you've already done...
Old 11-14-2013, 10:43 AM
I run motorcraft plugs and wires
Old 11-14-2013, 05:44 PM
Well, there goes my theory. I've had similar codes with cars that had Bosch or other supposed "better" plugs...
Old 11-14-2013, 08:57 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Have you replaced the O2 sensors?
Old 11-17-2013, 09:33 PM
I replaced all 3 o2 sensors on my truck
Code P0153 P0133 2000 Ranger just report it as stolen? rogerranger2122 Ranger & B-Series 23 08-08-2016 06:24 PM
Vacum routing therigwelder 1997 - 2003 F150 1 07-23-2016 01:35 AM
Check Engine Light - Running Rich! Gryphon1962m 1987 - 1996 F150 & Larger F-Series Trucks 13 06-03-2016 07:52 AM
P0344 and P0340 with some helpful information about camshaft position sensors NM3 2004 - 2008 F150 2 01-19-2016 05:52 AM
1992 f150 4.9 problems, please help jduckworth18 Ford Inline Six, 200, 250, 4.9L / 300 3 03-27-2015 11:29 PM
Tags
4.9l, need help, trouble codes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
