Winter Weather/ Freezing Weather Advisory - Ford Truck Enthusiasts Forums
Kentucky Chapter Join Chapter, Leader: SideWinder4.9l
Old 11-12-2013, 10:58 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Post Winter Weather/ Freezing Weather Advisory
It is getting that time of the year again folks... Yep, old man winter has tried to creep up on us yet again.
Here's some general tips for beating the big freeze:
- Be sure to carry 1-2 blankets, tire plugging kit, 2-3 cans of De-Icer and a set of Charging Cables for emergency use.
-Buy a cheap Antifreeze Coolant Tester ($1.00-5.00) and make sure your engine coolant is safe for sub freezing temperatures (0C/ 32F)
-If you become stuck and must run your engine for any length of time until help arrives, makes sure to crack 2 windows about 1" to vent fresh air in. Carbon Monoxide can build up and seep into the cabin of the vehicle and due its' worst on you. It is nothing to play with.
-Always make sure to keep your fuel tank as close to Full as possible and if possible, carry a 2-5 gallon gasoline can with extra fuel. You simply never know.
-For those of you with pets outside, make sure to keep extra fresh water available during daylight hours, as most animals will drink more at those times. Also, with the dark, water freezes with dropping temps.
-Keep a bag of cat litter or 2 in the trunk in case of getting stuck, as it can aid in traction. A small folding shovel is also highly recommnded.
--Take your car to a local Auto Parts store and have your battery and Alternator tested. Nothing makes a day worse than a dead battery. Most places perform this service for Free.
tankless or what at called "on-demand" water heaters RV_Tech Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 14 03-20-2014 03:26 PM
How to keep form getting frozen out Yahiko 6.0L Power Stroke Diesel 3 11-18-2013 11:19 PM
Winter Weather and Frozen Doors : Easy fix Yahiko 1999 to 2016 Super Duty 23 11-17-2013 04:37 PM
cold weather fix RocketmAAn 1968-2013 Full Size Vans 2 02-26-2012 01:10 PM
Accurately Measuring Coolant Freezing Point krankshaft Aerostar 5 11-26-2008 07:42 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
