1960 F100 restoration - Ford Truck Enthusiasts Forums
Ohio Chapter Join Chapter, Leader: RUNVS
Old 11-12-2013, 03:55 PM
sunman sunman is offline
sunman is starting off with a positive reputation.
Time to retire and work on my stock Fleetside 1960 F100 w/292 and manual 3 spd transmission. This truck has the large wrap around rear window. I'm trying to decide whether to leave it stock or go resto mod with a 351 Cleveland and auto transmission. I have the motor but no trans. Looking for suggestions and places to get parts. Thanks
Old 11-13-2013, 01:29 PM
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.
Hi,I would suggest you ask on the 57-60 forum. I just sold a big 57. I have alot of parts but not much for a 1960
Old 11-15-2013, 01:42 AM
bmuhlbach's Avatar
bmuhlbach bmuhlbach is offline
bmuhlbach is gaining momentum as a positive member of FTE.bmuhlbach is gaining momentum as a positive member of FTE.
With a 351 Cleveland you can get a trans from 250,300 289,302 or 351 Windsor.There is the c6 or c4 in the 80's Ford changed the balance of the flywheel on the 302 from 28 oz to 50 oz.A Cleveland would need a 28 oz. flywheel.Other thing is Ford used a 157 tooth and 161 tooth flywheel you can buy them new I believe Summit sells them.I put a 351w in a 56 Fairlane used 1977 302 F150 motor mounts and it bolted down to the frame on the Fairlane.
Old 11-19-2013, 09:13 PM
Thanks for the advice.
Old 11-19-2013, 10:19 PM
bmuhlbach's Avatar
Where you at in Ohio?See if ther is a pull a part by you the one on West 130th street in Cleveland has lots of vans easy to drop them out.That would be a C6 for the most part.
Old 11-20-2013, 06:47 PM
Thanks for the info. I've got a good idea where the you pull it is. Im in Port Clinton. I have to check the numbers on the 351. I was informed by a friend that the 351 was a Windsor. I don't mean to vacillate but the 292 runs strong and the truck has 67k. Minimal rust. Maybe I would be better off keeping it stock. It would make a bad *** truck with C6 behind the 351. Thanks again guys. by the way, how do I join the Ohio Chapter?
Old 11-20-2013, 08:41 PM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is offline
bigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud of
Quote:
I have a hood and a lot of y block parts. send me an email bigwin56f100@yahoo.com
Old 11-20-2013, 10:40 PM
bmuhlbach's Avatar
Aod help Houser16 1957 - 1960 F100 & Larger F-Series Trucks 0 07-18-2016 11:29 PM
1960 aod transmission swap Houser16 Engine Swaps 18 03-01-2016 11:57 PM
WTB 1960 F100 steering box Divingjack WTB - Parts & other 0 12-13-2014 11:46 PM
1960 Ford F100 Kenny 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 06-07-2013 11:06 PM
Rear axle ratio change? lwclark 1957 - 1960 F100 & Larger F-Series Trucks 8 05-01-2012 07:28 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
