1998 conversion e150- 4.6 engine with c1095 code - Ford Truck Enthusiasts Forums
Old 11-12-2013, 03:49 PM
rustypierce rustypierce is offline
rustypierce is starting off with a positive reputation.
I am rather new to this site and I also posted this in the Ford econoline van forum. I Hope I am not breaking any posting rules!
This is an open circuit code
I have inspected the wiring harness and found nothing peculiar.
What I did find, is the ABS module is a F7UA-2C346-AC and I cannot find this part anywhere on the internet. It does not match what OEM e150 says it should have F8UZ-2C219-AA
It's made by Kelsey Hayes. it has 3 connections on it. It has a 20 pin connector from the wiring harness and another 2 blade connector from a harness. It also has one more 2 blade connection with wire going from ABS module to pump motor.
I have voltage power to the ABS module and also voltage power out of the ABS module to the pump motor.
Any Suggestions for additional testing?
ABS Light - Code C1096 - Fix JustFixIt 1997-2006 Expedition & Navigator 3 08-05-2015 05:21 PM
1966 F600 Rear Brake Question Pbbbfischer 1961 - 1966 F-100 & Larger F-Series Trucks 4 07-18-2015 08:49 PM
1966 F600 Rear Brake Question Pbbbfischer Large Truck 1 07-18-2015 04:48 PM
does RED lead on DSII need power on start? annaleigh 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 21 05-01-2015 04:49 PM
1998 conversion e150- 4.6 engine with c1095 code rustypierce 1968-2013 Full Size Vans 4 02-22-2014 07:18 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
