1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Ford Cummins Conversion Video
Old 11-12-2013, 01:39 PM
Yellowsuperduty's Avatar
Yellowsuperduty
Yellowsuperduty is offline
This is my 99 ford f-250 Super Duty with an 05-07 front end conversion that previously housed a Triton V10 gas motor and automatic transmission that i converted to a 12v Cummins turbo diesel and a 5 speed manual. Hope you enjoy the video.
Old 11-12-2013, 02:13 PM
truckfella's Avatar
truckfella
truckfella is offline
How big of a job was it to pull off the front end conversion? Did you have a good set of instructions or were you winging it?
Old 11-12-2013, 02:16 PM
scotttahoe's Avatar
scotttahoe
scotttahoe is offline
Wow sick video! Love the mini Peterbilt too! Way cool!
Old 11-12-2013, 02:17 PM
scotttahoe's Avatar
scotttahoe
Welcome FTE. Wow sick video! Love the mini Peterbilt too! Way cool!
Old 11-12-2013, 02:57 PM
Yellowsuperduty
No i didnt have any instructions. Once you have the 05-07 header panel in place everything bolts up rather easily
Old 11-12-2013, 02:59 PM
Yellowsuperduty
Thanks for watching i really appreciate it
Old 11-12-2013, 03:22 PM
truckfella's Avatar
truckfella
That is way cool. I had a 12v Cummins in a Dodge truck about 15 years ago. It was an "ok" truck but an outstanding engine! A little noisy by today's standards but pretty much bulletproof.
Well done!
Old 11-12-2013, 03:25 PM
Yellowsuperduty
Well done!
Thank you Yeah its defiantly noisy, the stacks don't help either lol. Your truck is very nice too by the way.
Old 11-12-2013, 04:06 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
Very cool!, how hard was it for you to swap in the cummins? Been wanting to do a 12v swap for a long time, any mods done to it or is it stock?
Old 11-12-2013, 04:24 PM
Yellowsuperduty
Just takes some time and fabrication. I had to run new lines and install a draw straw in the fuel tank. make all the motor and transmission mounts, cut the floor out for the transmission. I actually used the stock ford transfer case and drive lines just had to change the input shaft on the t case to match the dodge tranny. and the a lot of odds and ends and making the stock gauges work. Only mods are the afc arm is cut, took the fuel plate out and put a boost elbow in plus exhaust and intake
jrandol
Engine Swaps
10-05-2009 04:10 PM
Fomoko1
37
07-07-2008 11:42 PM
zigzkidz
General Diesel Discussion
03-31-2007 05:10 PM
Quick Reply: Ford Cummins Conversion Video
