Ford Cummins Conversion Video - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-12-2013, 02:39 PM
Yellowsuperduty's Avatar
Yellowsuperduty Yellowsuperduty is offline
Yellowsuperduty is starting off with a positive reputation.
This is my 99 ford f-250 Super Duty with an 05-07 front end conversion that previously housed a Triton V10 gas motor and automatic transmission that i converted to a 12v Cummins turbo diesel and a 5 speed manual. Hope you enjoy the video.
Old 11-12-2013, 03:13 PM
truckfella's Avatar
truckfella truckfella is offline
truckfella has a good reputation on FTE.truckfella has a good reputation on FTE.
How big of a job was it to pull off the front end conversion? Did you have a good set of instructions or were you winging it?
Old 11-12-2013, 03:16 PM
scotttahoe's Avatar
scotttahoe scotttahoe is offline
Under Construction
scotttahoe is a splendid one to beholdscotttahoe is a splendid one to beholdscotttahoe is a splendid one to beholdscotttahoe is a splendid one to beholdscotttahoe is a splendid one to beholdscotttahoe is a splendid one to beholdscotttahoe is a splendid one to behold
Wow sick video! Love the mini Peterbilt too! Way cool!
Old 11-12-2013, 03:17 PM
scotttahoe's Avatar
Under Construction
Welcome FTE. Wow sick video! Love the mini Peterbilt too! Way cool!
Old 11-12-2013, 03:57 PM
Quote:
No i didnt have any instructions. Once you have the 05-07 header panel in place everything bolts up rather easily
Old 11-12-2013, 03:59 PM
Quote:
Thanks for watching i really appreciate it
Old 11-12-2013, 04:22 PM
truckfella's Avatar
That is way cool. I had a 12v Cummins in a Dodge truck about 15 years ago. It was an "ok" truck but an outstanding engine! A little noisy by today's standards but pretty much bulletproof.
Well done!
Old 11-12-2013, 04:25 PM
Well done!
Thank you Yeah its defiantly noisy, the stacks don't help either lol. Your truck is very nice too by the way.
Old 11-12-2013, 05:06 PM
xmontex4's Avatar
xmontex4 xmontex4 is offline
xmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to all
Very cool!, how hard was it for you to swap in the cummins? Been wanting to do a 12v swap for a long time, any mods done to it or is it stock?
Old 11-12-2013, 05:24 PM
Quote:
Just takes some time and fabrication. I had to run new lines and install a draw straw in the fuel tank. make all the motor and transmission mounts, cut the floor out for the transmission. I actually used the stock ford transfer case and drive lines just had to change the input shaft on the t case to match the dodge tranny. and the a lot of odds and ends and making the stock gauges work. Only mods are the afc arm is cut, took the fuel plate out and put a boost elbow in plus exhaust and intake
Not about the OBS but still a cool video... krooser 1987 - 1996 F150 & Larger F-Series Trucks 3 06-24-2015 03:20 AM
Interesting video Watcher58 General Automotive Discussion 10 06-24-2015 01:07 AM
1969 Ford F600 Cummins conversion OldTimerDually Large Truck 13 07-12-2014 09:49 PM
F-250 Superduty ball joint video jayft8 1999 to 2016 Super Duty 0 03-02-2014 12:55 PM
Video: Ford F250 and Explorer Crash Test GermanMike Excursion - King of SUVs 20 10-28-2013 12:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
