Oil Pressure Sensor
Oil Pressure Sensor
Have my 2008 F-250 with the 2006 engine. I would like to install an external, mechanical Oil Pressure Gauge. I am used to the pressure sending unit being install above the oil filter on the oil filter adaptor bracket, on the left side of the engine.
Where that bracket is normally mounted I have a bracket strictly for mounting the lower radiator hose.
Well, my oil filter is mounted on its own bracket, toward the rear of the engine, left side, and I cannot find a pressure sending unit anywhere.
I do have a very large plastic nut with two connectors inside, mounted on the oil pan, on the right side of the oil pan. Nothing is connected to it and there are no wire anywhere near it. What is that thing for????
Looking forward to the help I know I will get.
thanks everyone
Martin
thanks everyone
Martin
thanks everyone
Martin
thanks everyone
Martin
I don't know where the motor came from. I am half tempted to say a Mustang as I have a Oil Temperature Sensor in the Oil Pan (not hooked up) and I don't be believe that the trucks have that option. Also I am not able to post pictures. The area where the "normal" adaptor plate is only has the radiator hose coming to the engine. My oil filter is mounted about a foot further back hanging upside down on its own bracket. I will say, it is one of the easiest to change I have ever experienced.
rottenstock
17
06-28-2012 05:36 PM
