5 speed mainteance
Received 3,695 Likes
on
I recently changed mine to AMSOIL syncromesh what a difference it made. before I could not downshift and shifting was stiff with the syncromesh oil I can downshift every gear but second.
I have run mobil 1 synthetic atf, mobil 1 synthetic 5w20 motor oil. and now the syncromesh
on
Synchromesh is known for eating syncros of certain material/design. I think it's too aggressive or not slippery enough and they wear out.
If it's shifting hard with synthetic ATF (or whatever oem fluid is) then you have other issues.
I run redline shockproof and synchromesh in my awd import trans and my t5, but failure is caused my my heavy foot and hard shifts, not improper fluid.
I'd research what type of syncros are in the zf, and compare to the gm trans and maybe it's compatible.
Redline D4 seems to be the most appropriate as it is synthetic and is said to meet the specs for Dex II, Dex III, Merc, and Merc V applications. The ZF calls for Mercon Synthetic ATF in the manual. I'll be using that or Amsoil Torque-Drive on my next swap any time now. Been running RP Max ATF for almost 40k and can tell it's time for refreshing.
I stay away from royal purple products except for short term or racing applications.
Daily drivers and work vehicles I stay away from rp because it oxidizes in a short amount of time. I rebuilt the rear axle of my superduty and pressurewashed and degreased the whole thing to start fresh, all new everything, and put rp in the diff. 10k later did an oil analasys and they said I had to change fluid. I researched and quite a few people (at the time) were having the same issues with diffs, and manual trans. No issues with engine or autos from what I remember though.
I'll stick with Schaeffer or Amsoil. I use Mobil 1 to flush the system for 5k and then switch to the good stuff.
I really like redline products for heavy duty applications. Never got to do OA on it though, so I don't know how it lasts long term.
Anyone have an opinion on this? Schaeffer Oil | ALL-Trans Supreme® Transmission Fluid for Dexron III and Mercon fluids
I previously only used Mobil 1 products, I still do, but I really prefer Schaeffer products now. I was an Amsoil dealer, I moved from my big welding fab shop in Maine to just outside philly, and don't have a big business anymore so I got out of selling it.
I use Amsoil in atv stuff, Mobil 1 in daily driver cars and trucks, Schaeffer in my work trucks and hot vehicles, and some equipment. My dump truck and big equipment gets Dino oil, because it's already expensive to replace 20-40quarts using cheap oil.
Anyway
I recommend most all Schaeffer oils, and don't see a problem with Amsoil, or Mobil 1. It's only dependent on your budget.
flipklos
08-26-2011 06:52 PM
