help 08 escape hybrid wont start
Hello I just bought a 08 hybrid escape the problem is it won't start it has a red triangle, yellow wrench, and check engine light on
Things I've done :
Check shut off buttons front and rear
Pushed the charge button and waited until it started to blink with and without another car jumping
When I pressed the charge button with another car jumping it I heard noise from engine compartment
Now when I try to crank it sounds like a click from lower fuse box inside car
Had the codes read
Bo122
B0223
B0606
B2110
I've replaced the battery under the hood
All I know about the car is its been sitting and it couldn't be started
The car started for maybe 5 seconds this morning I tried to give it gas and it shut off
If I need to change parts are the parts interchangeable with other years or models
Things I've done :
Had the codes read
Bo122
B0223
B0606
B2110
