54 F100 build
54 F100 build
I am replacing the engine and tranny with a 302 and c4...i have a strait axle and original steering. What headers will work ? I searched the threads but could not come up with the answer.
Thanks in advance.
Thanks in advance.
Thanks, just purchased the motor mount x member, pads and trans supprt from mid fifty...Diane was very helpful but indicated that the trans pad was out of stock...i am planning to do the install this weekend...does anyone know what part number or manufacturer of that trans pad ? I d like to pick one up locally (vancouver) if I can.
Thanks again for your all your replies...
If you are talking about the mount that goes between the C4 and the crossmember, this is the one I used:
Anchor 2253 - Transmission Mount | O'Reilly Auto Parts
It was in stock at my local O'Reilly's and Napa. Any decent auto parts store should be able to get it for you.
I have a 351 and C6, and I'm using the stock manifolds that came with the 351. Remember when purchasing headers, that mustang headers won't work as the drivers side there is clearance issues with the gear box. Found out the hard way, I have a really nice pair of chrome small block ford headers that I can't use because of the gear box. Passenger side not a problem. You need to find some headers that drop similar to the stock between the 3rd and 4th cylinders.
Thanks
SBF headers are the same unless you have speciality heads. It is the chassis that they are made for that is different. It is the width of the motor that will cause most issues, so because they don't fit in a 351 truck does not mean they won't fit a 302 truck. When I had my stock front suspension, early Mustang headers fit with no problems.
Cheers,
