5w-40 Rotella Synthetic Thought's Suggestion's - Ford Truck Enthusiasts Forums
Old 11-11-2013, 08:04 AM
tankd72's Avatar
tankd72 tankd72 is offline
tankd72 is starting off with a positive reputation.
I am thinking of switching oil I have been using Rotella 15W40 dino oil since I bought my 2004 6.0. It just turned 101,000miles and I have an oil change coming due soon. I did a search on the 5w-40 Rotella Synthetic and the only in the 7.3 forums was there any discussions. I do have the cold start injector sticking until it gets to operating temp. I am hoping that the lighter oil and being synthetic it may help. The 7.3 guys claim it helps on cold starts and engine diesel clatter is quietier.. Thoughts
Old 11-11-2013, 08:08 AM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
I run T6 5W-40 all year. I've been happy with it.
Old 11-11-2013, 08:14 AM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
T-6 is great, my truck loves it. You may also want to check your ficm voltage. That can also cause rough cold starts.
Old 11-11-2013, 08:42 AM
tankd72's Avatar
Thanks for the replies I will goe to Wally World and get some. I checked my ficm and had good 56v when it was cold well 50deg I am in Gilbert AZ. I was talking to anoter 6.0 owner while fueling the other day he had the same rough idle when cold. He said that the spool shuttle valve thing on the injectors stick when cold and ford reflashed his truck with a warming option for the valve thing and it works great now. I also saw on You Tube a guy ended up using a whole big jug of diesel kleen silver and a quart of 2stroke oil in his excursion with 6.0, 2 tank fulls later no more sticky injectors, Another You Tube a guy with 6.0 was ready to do oil change tha t afternoon, so He poured a big bottle of marvel mystery oil in it drove around that morning and after his oil change no more sticky injectors. Any thoughts or experiences with either of these?
Old 11-11-2013, 08:44 AM
mohle's Avatar
mohle mohle is offline
mohle is starting off with a positive reputation.
5W40 is good for all year running. Probably the best grade of oil to run. As far as synthetic go, I really don't think there is much of a difference between them all. They are all good. Pretty much personal choice, sort of like what tastes better, Coke or Pepsi.
Old 11-11-2013, 09:17 AM
clevelandtundra clevelandtundra is offline
clevelandtundra is gaining momentum as a positive member of FTE.
I run T6 5w40 all year round too. Gets up near 90*F in the summer and down to <10*F in the winter. I haven't sent my oil out for any kind of analysis but going off feel I can tell the truck has a much easier time starting in the winter compared to the dino when I drove it off the dealer lot.
Old 11-11-2013, 09:25 AM
tankd72's Avatar
Thanks for the input. I think what I may do is switch to 5w-40syn during the cooler months and back to 15w-40 during the hot months because we hover around 110*F-115*F from end of May through September. However I didnt see that Wally World carried Rotella 15w-40 in synthetic only dino.
Old 11-11-2013, 09:37 AM
the_auto_tech's Avatar
the_auto_tech the_auto_tech is offline
the_auto_tech has a good reputation on FTE.the_auto_tech has a good reputation on FTE.the_auto_tech has a good reputation on FTE.
T6 for sure. My truck had 15W40 in it when I bought it and I got to experience a few cold starts with it. The T6 starts MUCH better.
Old 11-11-2013, 10:47 AM
Mich6.0 Mich6.0 is offline
Mich6.0 is starting off with a positive reputation.
Been running it for years now and no problems
Old 11-11-2013, 11:09 AM
99ExpyProblems 99ExpyProblems is offline
99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.
I'm switching to T5 10w30. I ran 15w40 and then Delo 5w40. If I like the T5 (won't know for another 1000 miles, I'll be sticking with it for $5 cheaper per gallon.
Old 11-11-2013, 11:18 AM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Quote:
Stiction is on the oil side of the injector, not the fuel side.
Josh
Old 11-11-2013, 12:21 PM
diesel_dan's Avatar
diesel_dan diesel_dan is online now
FTE Addict
diesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to behold
If they don't have that, they should have the Delo 400 5w 40 full syn. It's a touch cheaper and every bit as good as the Rotella. Just another option for you...
Old 11-11-2013, 12:36 PM
dvldog13's Avatar
dvldog13 dvldog13 is offline
dvldog13 is starting off with a positive reputation.
I just changed from schaffers syn 5w40 to rotella syn.........was chasing a stiction problem.......talked to Ed from FICMrepair.com. He sells a product called hot shot secret.......It is a oil and a fuel additive to remove the stuff in the injectors...........I wasnt one to believe in a " mechanic in a can" snake oil crap..........but @ 300.00 a pop for an injector.......i tried it...........so far so good......mileage is back up .........running like new.....lots of power...and no i am not an actor or paid professional...........But it has worked so far.....good luck
Mike
Old 11-11-2013, 12:45 PM
jswartz84's Avatar
jswartz84 jswartz84 is online now
jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.
I wouldnt think 50* would be cold enough to cause stiction or warrant using anything but a 15W40 oil. Its been in the 30* range where I am and I haven't noticed anything. I'm running Delo 15W40 LE. Of course my oil hardly gets more then 2500 miles on it before I change it due to time. What are your oil change intervals?
Old 11-11-2013, 12:51 PM
Bullitt390's Avatar
Quote:
Depending on what PCM/ FICM strategy is loaded can be night and day difference concerning 15/40 and temps under say 40.
Josh
Synthetic to Dino Rotella?? Supercab 1999 - 2003 7.3L Power Stroke Diesel 2 01-14-2017 04:48 PM
Dino 15W-40 to Rotella T-6 5W-40 tom from mass 1987 - 1996 F150 & Larger F-Series Trucks 13 01-21-2016 02:59 PM
Mobil 1 Synthetic 5W-40 HKusp 1999 - 2003 7.3L Power Stroke Diesel 66 07-06-2014 03:04 PM
Cheap Rotella T6 dannyboy7.3 6.7L Power Stroke Diesel 19 05-12-2013 01:25 PM
Changing to Rotella Syn 5w40... may BillyBob69 1999 - 2003 7.3L Power Stroke Diesel 30 01-09-2010 12:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
