Long flat "washers" on valve covers
I had a pretty massive oil leak on my 6.9 and discovered that two of the valve cover bolts had completely come out and were missing. The bolts have some long flat washers that help hold/spread the valve cover over a larger area of gasket.
Anyone have a source for these? I need 2.
Found these a second ago:
Chevy Full Size Chevy Valve Cover Bolt & Washer Kit, 409ci, 1964-1965 - Ecklers Late Great Chevy
I'm going to order a set (4) of the second ones (the wider of the two) to see if they can be made to work on a 6.9 valve cover. Will report back once they come and I can compare.
Edit - I ordered 4 of these which were much cheaper than the edlebrock. 5/16" bolt holes.
Got them in a couple days ago and it looks like they will be a good fit for the side bolts. The ones I have are kinda shaped like a [ turned on its side. The bolt is in the center. I will add a small washer so that the cinch points look more like a m instead of an n. Same size bolt hole opening as OEM clamps.
71FoMoCo
06-05-2003 05:34 PM
