Help with dome light please.
I have been searching all over the forums and still can't figure this one out. My dome/cargo lights will not work with the dash switch or when any door opens while the key is on. They do work when I use my key fob to unlock the doors or when I first shut the truck off. My door switches are working fine, I think, I get the door ajar on the dash when either door opens and it does not stay on when they are shut. but here is the weird part. When I start the truck with the door open, it locks the door like it is not recognizing the door is open I am guessing probably Gem module, But could it be vsm? How can I be sure, what do I test? It is really starting to drive me crazy. Please help.
There's a small relay in your fuse pannel under the steering wheel. Bottom or top I don't recall with 4 prong sticking out of the it where it plugs in. I had a random problem until one day it just went out and I could hear it clicking over the engine running. It's worth changing if you havent yet.
The vsm relays are deep behind the radio. Basically at the firewall, pull radio and you can see the blAck cover. Size of snickers bar.
Cover just snaps over a tab on each end. I removed cup holder and entire lower dash to be able to remove the cover and relays.
No answer to prob. Sorry, not sure how vsm effects dome
It's in my signature. E99 F-250. My issue was a little different as the dome lights pretty much had a mind of it's own turned on coming to a stop, took of at about 15MPH the went off, turned off at key off door open, etc. Someone mentioned to spray a little WD into there and I figured can't hurt and fixed it up after I wired a toggle switch from the fuse box, go figure. Unfortunately to me yours does sound like it's also elsewhere.
Rakkasan187
1999 to 2016 Super Duty
04-11-2017 10:30 AM
artieb
03-30-2016 11:51 AM
TX_Toyhaulr
03-07-2009 12:24 AM
