Pinion yoke drag
Pinion yoke drag
My replacement axle has the wrong yoke, so I need to swap in the old one.
Anyone remember the torque spec for setting it?
I cannot remember if you need to use a new crush sleeve when doing it as well.
Limited tools makes this a pita. And I don't really want to remove the carrier.
I know you can do it without having any issues, but I just don't remember all the steps, only the steps for setting up new stuff.
I've changed my yoke 2 times now and haven't replaced the crush sleeve. I was told by multiple "old timers" including my father and uncle that all you need to do is count the exact number of times it spins off when you remove it, and reinstall the same number. I used some of my girlfriends nail polish to mark the socket (i believe its 1 1/8, can't recall) and marked the yoke correspondingly. Then counted each half turn. Its a real bitch to do, you definitely know when you get there because once you reach about where that crush sleeve was crushed it gets HARD to turn.
woodtrucker
12-13-2013 06:22 AM
bbf150
05-22-2013 08:45 PM
kopfenjager
03-02-2005 12:42 AM
