1962 F100 Restomod - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
1962 F100 Restomod
Old 11-10-2013, 04:52 PM
62UniFORD's Avatar
62UniFORD 62UniFORD is offline
62UniFORD is starting off with a positive reputation.
1962 F100 Restomod
I have just started working a project that really means alot to me. It is a 1962 F100 Uni-body pick up. I use to have a 61 that my stepfather gave me a long time ago. When my stepfather passed away my mother ended up moving.The truck had gotten left behind and then disappeared. My brother gave me this 62 in place of it so I am building it in memory of my stepfather.
Old 11-10-2013, 07:55 PM
okiewelder okiewelder is offline
okiewelder is starting off with a positive reputation.
Good luck! What are your plans for her? I bought my first one in 86 because l had a good friend that had one. He died and a few weeks later l was at the salvage yard and there was one just like his. I have had it ever since. Another year or so and mine should be back on the road.
Old 11-10-2013, 08:14 PM
62UniFORD's Avatar
So far I am planning a Crown Vic front end swap, boxing in the frame for strength, and doing a frame off. I am still working out what engine I want to run in it.
Old 11-11-2013, 09:29 AM
Uni Moe's Avatar
Uni Moe Uni Moe is online now
Uni Moe is starting off with a positive reputation.
I see the F O R D is in the center of the grill. Would that make it a 61?
Old 11-11-2013, 11:59 AM
62UniFORD's Avatar
I noticed that when my brother gave it to me and he swears it's a 62. It has been wreaked in the front so I'm thinking someone put a 61 grill and upper piece in it.
Old 11-11-2013, 04:45 PM
62UniFORD's Avatar
Here is a pic of the VIN plate if someone knows how to make sure for me.
Old 11-14-2013, 09:17 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Vin is camera washed
The first three look like 154 Which makes it a march of 1960 production.
150,000 to 159,999
Its a 61.
The plate is a 61 or 62 plate by use of the serial number above the VIN. Later 63 up plates removed this nomenclature to say "Warranty Number"
Garbz
Old 11-15-2013, 05:19 PM
62UniFORD's Avatar
Thanks, I guess I should change the name of this thread.
Old 11-16-2013, 05:28 PM
62UniFORD's Avatar
I started dis-assembly last weekend. I got the front end off and found a lot more sure holes than I thought.
The jnuts on the fenders were broken so I had to cut holes in them just to get them off.
This is the amount of bondo I found in the passenger side fender.
Old 11-24-2013, 10:58 AM
62UniFORD's Avatar
Well I got more work done of it yesterday. It's a little cold out there today so I'm going to do more research of parts that I know I need so far. Here are a few pics of what I got done yesterday.
I took the seat, fuel tank, and mats out and this is what I found.
The steering column was kind of fun to take out but I got it.
I know they make the two floorboad panels but does anyone know if anyone makes the lower firewall panel?
Old 01-12-2014, 02:44 PM
62UniFORD's Avatar
Well I have figured out what engine I am putting in this thing and how I want to build it.
460
block
Stock crankshaft
ARP 350-6802 - ARP Crank Pulley Bolts
ARP 150-2501 - ARP Balancer Bolt Kits
ARP 255-5502 - ARP Main Stud Kits
Eagle H-Beam Connecting Rods 6605F3D
Milodon 31929 - Milodon Street and Strip Oil Pan Kits
Milodon Stainless Steel Oil Dipsticks 22035
Ford Racing M-6600-A460 - Ford Racing High-Volume Oil Pumps
Keith Black/KB Pistons KB137KTM-30 -
Keith Black KB Performance Piston and Ring Kits
Valve train
D0VE heads with larger valves, port job, chambers polished and port match
(330-ish/190-ish cfm flow @.600)
Intake valve size increased to 2.19
Exhaust valve size increased to 1.76
COMP Cams Xtreme Energy Cam and Lifter Kits K34-247-4
COMP Cams High Energy Die-Cast Aluminum Rocker Arms 17045-16
Lunati Pro Series Stud Girdles 91647
Crane Rocker Arm Guideplate Conversion Kits 52655-16
Air/Fuel
Weiand Stealth Intake Manifolds 8012
FAST EZ-EFI Self-Tuning Fuel Injection Systems 30227-KIT
Bear claws with original handles gdub 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 12-06-2014 10:33 AM
Something old, something new bobj49f2 1948 - 1956 F1, F100 & Larger F-Series Trucks 34 06-26-2013 09:40 PM
Pictures at the Ford Truck Show Red Ford Truck Ontario Chapter 39 10-26-2012 06:36 PM
56 F100 Progress gquinn8516 1948 - 1956 F1, F100 & Larger F-Series Trucks 104 12-02-2010 07:16 AM
any one here know how to wire up a truck joe f350 The Next Generation 13 02-05-2009 02:25 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
