A Radiator Story
Geeeze that came out SWEET, cant wait for the weather to warm up around here so I can start my radiator install. Cant quite make out what # upper hose you are using, could you advise please........Thanks
Also what are you using in the RH side of the lower tank, think it's for your electric fan, am I going to have to plug the opening.....THX
Top hose is a 20088. What you're seeing on the bottom right tank is a ball valve, 1/4" NPT on one end, 5/16 hose barb on the other. I plan on putting a small piece of rubber hose on it for cooling system service. One thing I won't tolerate is coolant going all over the place. I own dogs and don't wanna kill 'em. This method will allow me to put the hose in a gallon milk jug and shut it off when it's full. Drain out a gallon of 50/50 antifreeze and distilled water once a year, fill it back up and I shouldn't need to do any other maintenance on the cooling system other than the once every five years hose replacement
Looks good. I wonder if you could modify the mounting tabs so it could site farther forward in the original position. Right now it's sitting a full radaiator's width back, closer to the engine. I plan on running an electric fan also but wanted to mount it on the other side so it's setup as a puller.
crazy96863
20
10-15-2020 09:12 AM
Warhawk77
13
09-18-2017 10:17 AM
JTB321
09-11-2016 10:15 PM
